Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door operators when it is disconnected
When the door is connected it goes up about 8" and stops
  • Anonymous Dec 21, 2008
    I have the same problem in the cold weather, usually below -10 with out the sun. I have found that If I disconnect the opener from the door , close the door manually then activate the opener to the closed position, it will stay closed. I believe this has more to do with the door resistance (since it is cold) than the opener as the opener is only doing what it is designed to do and sense the resistence. You may find adjusting the door opener sensitivity in cold weather will correct the problem - wcc
    Sniper:
  • 98 Answers
You might have a broken spring. Check on the a the header above the door there should be a tude with a drum on each end and 2 springs (maybe one) towards the center. If one of the springs has a gap (1-2 inches) in it. If it does you will need to call a door company in your area. I recommend you replace both springs. If you need to get you cars out some times you can help the operator to lift the door by lifting the door while the operator is lifting the door. Be very careful not to get your fingers in a pinch point and be sure to lower the door the same way.
Posted on Jan 03, 2009
The garage door won't open. It goes up maybe an inch and stops. It flashes 4 times which corresponds to an obstruction, but I don't see anything. It will go back down. Thanks
Disconnect the door from the opener by pulling the emergency opener. Then operate the door manually to see if it hangs up. If it does, then address the problem.
Jan 06, 2018 | Building Materials
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
07f error code... duet washer W9150
Tech sheet on this model:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/proceedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Every time I push the opener button the chain goes about an inch and stops abruptly. The door is not able to be opened or closed as a result. Is this an adjustment problem?
Disconnect the opener from the door.
Lift the door and ensure that it moves freely from fully open to fully closed.
Try to operate the opener. Does it go all the way from open to cloosed?
If the door operates smoothly and the opener works without the door connected, check the up/down force adjustment on the body of the opener.
Dec 01, 2010 | liftmaster Chamberlain Garage Door Opener...
My liftmaster garage door only opens 8 inches and then stops
It sounds like the opener is stopping because the weight of the door is tripping the lift sensor on the opener. There are two screws on the side of the opener to adjust the lift and close pressure. Find the lift pressure screw and ajust it higher to see if that remedies the problem.
Also, because you said the door will not stay open at the top when you open it manually, I think your springs are not adjusted correctly. They should hold the door open in the up position when not connected to the door opener. That may be the reason the opener lift pressure is kicking it out.
If you have to adjust the springs, be careful that you know what you are doing. There is a lot of potential for getting hurt if you don't know the proper proceedure.
Good luck.
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door goes up, but only travels about 12 inches and stops when it comes down
TRY HOLDING DOWN THE WALL BUTTON TO CLOSE THE DOOR.
IF IT WORKS THE PROBLEM IS IN THE SAFETY EYES.
IF THE DOOR TRUELY GOES A FOOT OR MORE AND THE ABOVE DOES NOT WORK - DISCONNECT THE DOOR FROM THE OPENER AND MAKE SURE IT WORKS SMOOTHLY - LUBE THE SPRING(S) ETC,
IF IT GOES UP AND DOWN WITHOUT TOO MUCH EFFORT ADJUST THE DOWN SENSITIVITY - NOTE: THIS IS A VERY SMALL ADJUSTMENT 1/8 TURN IS MORE THAN ENOUGH
IF YOU STILL HAVE PROBLEMS DOWNLOAD THE OWNERSMANUAL FROM LIFTMASTER.COM NAD READ THE TROUBLESHOOTING SECTION
HOPE THIS HELPS
Dec 20, 2009 | liftmaster Chamberlain Garage Door Opener...
Have a kenmore elite 3 washer...stopped with 8 mins left in cycle...try to restart but getting F DL code...cannot open washer door
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Replace the door lock mech if the wiring is ok
Oct 11, 2009 | Kenmore Washing Machines
GARAGE DOOR OPENER WORKS INTERMITTENLY
& to 10n years on a door opener is good. Did you set the pressure up high there are two dials on the back and they are numbered 1 2 3 to 10 set them to 8 or 9 and see if this solves your problem. What is happening is the sensors are tell your door its hitting something dose the light blink after it stops I need to know more. I would just buy a new one don't get this one fixed not worth it.
Jun 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
