Question about Samsung Televison & Video
WHITE DOTS ON SCREEN
HAVE 46 INCH SAMSUNG PROJECTION TV, DOTS STARTED WITH A FEW AND GOT MORE AND MORE OVER THE WEEKS. WHAT IS MY PROBLEM?
  • 1 more comment
  • johnjohn6939 Dec 04, 2008
    the tv is 2 years old and the model# is hls4676sx/xaa, i am trying the solution you gave me now, i will let you know if it works
  • johnjohn6939 Dec 05, 2008
    the hard reset did not work, what is my fix?
    the tv is 2 years old, model # is hls4676sx/xaa, the hard reset did not work, what do i do now?
    Sergeant:
  • 217 Answers
This is a problem is usually on your Y sustain board. There are two adjustments for this in which an Oscilloscope is nessesary for the alignment. However, there are two other things that can cause this also. This is beyond your abilities if your not a tech. Sorry for the news, It's not a major repair but should be done by a qualified tech.
Posted on Dec 05, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Let's try the easy one first. Check your signal source, your cable or aerial. White dots could be "snow" indicating low incoming TV signal level. The increasing number could be indicative of a worsening cable condition. If it were so, you may want to try and check your aerial or consult your cable TV provider.
Alternately, it can be RFI (radio frequency interference). Pls verify that there are no other electrical devices are plug in to the same outlet/line that could cause this such as wireless phone, lamp dimmers, electronic ballast, radio clock and others.
if it were something else internal to the TV such as a weakening or faulty tuner block/assy, then pls post back the exact model number of the Samsung TV.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 04, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 734 Answers
Hi, There is sum lousing in the earth wire (green wire) causing your tv screen showing dots.
Check the Green wire before any other operation.
Thanks
  • futureloginn
    futureloginn Dec 10, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Sounds like a the Screen is on it's way out. That's normally a sign of burnt out Pixels. If it's under warranty I'd send it back and have it looked at or replaced.
    Genius:
  • 1,550 Answers
You need to provide details about the model number of your tv .
How old is your tv ?
Have you tried hard reset .
Hard reset : Unplug the TV from power chord for about 30 minutes and plug back the power chord to the tv .
White Dots : It is due to faulty capacitor . The capacitor is not discharging properly.
Have Samsung D L P42 in ---problem white dots on screen
A DLP type set (any brand or model) uses a optical light engine= dots means a problem with the optical engine usually caused by the heat from the lamp affecting the lens unit or the engine itself---seen some with as many as 100 dots--engine would have to be replaced and they start at about 600+ or more.
Apr 14, 2012 | Televison & Video
White dots
Samsung DLPs, means Bad Light Engine
Call Encompass Parts 1-800-638-3328
or UED 1-800-648-6657
Apr 15, 2010 | Samsung SP 56 K 3 HV 56" Projection...
White spots are just emerging on my 46inch
There seems to be an issue with your DMD board, which is the on in charge of the pixelation. What you can do to confirm if it's indeed the DMD board, is the following: GO to the menu on the TV and if the dots show in the menu, it's your DMD board, but if they don't the issue might be with one of your Video Boards.
Dec 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on Samsung 50* Model
Yes, It is problem with DMD module in light engine that will be replaced.
Hope Samsung will help you in replacement. Please update about outcomes.
Thanks.
Sep 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on 50in dlp samsung
This is caused by dust or dirt in the Optical Block. Only a good TV Tech can solve this problem.Call one for an estimate.
Aug 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
SAMSUNG TV
Possible bad color wheel..need lamp code # to get correct
wheel part #.........................................T.
Nov 15, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
