Question about Nokia 3250 Cellular Phone
My mobile phone not turning on
My mobile phone gave a message of corrupted files, main closed, system errors. I turn it off and after sometime I turn it on and it works normally for 1 hour. Now my mobile phone wont turn on
  • Nokia Master
  • 1,800 Answers
A flash of the firmware is needed in this case u cant perform that cuz u nedd an expensive gear.
any way just give it to the nearedst phone repair sho tell them to flash ity its not costing a lot though
Posted on Dec 05, 2008
N2626 model when turned on just sometime after a blue screen
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
http://www.nokia.co.in/support/repair-and-recycle
Apr 11, 2011 | Nokia 2626 Mobile Phone
How should i send or receive data from other mobile.
  1. Use a cellphone with Bluetooth (wireless connection), or even a USB connection (which is a computer port). These are all good ways to communicate with other devices.
  2. If your computer does not have the hardware for a Bluetooth connection, then buy the adaptor, sometimes called a 'dongle'. The adapter plugs into a USB port. It will be quite cheap, something like 10 to 20 American dollars. This adapter will have software for the connection process, which lets you transfer files from the computer to your phone, and the other way around.
  3. Make sure your computer is equipped with Bluetooth technology (either integrated into the machine or a USB dongle) and active.
  4. Turn on Bluetooth on your mobile device.
  5. Turn on your phone and go into 'Settings' in the Main Menu
  6. Keep going down until you find 'Bluetooth' (Sometimes it may be under 'Connectivity)
  7. Click on it and find 'Turn Bluetooth on' (or something similar) and press 'On'. You can now send and receive files. Once you receive a file, it will most likely be under 'Received Files'. This option can often be found in the Settings or Connectivity menu of your phone.
  8. Pair your computer with your mobile device by making both devices discoverable (also known as visible or unhidden) in the Bluetooth options. Once both are visible, search for Bluetooth devices on your mobile phone
  9. Locate the name of your computer in the results list and select it.
  10. Enter a 4 to 8 digit passcode of your own choosing and press continue.
  11. Once your devices are paired, you can send and receive files.
  12. There are several methods to send a file to your mobile device. One method is to copy the file from your computer, navigate to your mobile device (often found in My Computer or My Bluetooth Places) and then paste the file to the phone. Another option is to right-click on the desired file and select Send To --> Bluetooth Device --> (mobile phone's name).
  13. While the file is being transferred, you should see a progress bar on your computer and/or phone. Once the file is finished transferring, a message stating such should show up on your device's screen.
  14. Find the transferred file on your mobile phone by using the phone's built-in file explorer.
Oct 20, 2010 | Computers & Internet
Can't turn off Hard Drive
The error means that you are using a file on the external hard drive and that it can not close that file when it is use. You have to close the program that is using the file first.
Example:
Lets go on the assumption that you have your music collection on the external. If you still have your music player running when you try to disconnect, you will be greeting with the same error message.
If the external contains any files that your Operating System uses, you will get this message anytime the computer is on. An example of this can be your "Page File".
Shutting the computer down correctly is your safest bet until you find exactly what file is being used and what program is using it. During shut down, the computer closes any running programs. With no programs running, it will safely disconnect from the external HD because there will be no files in use.
If you manually disconnect it while the file is in use, you could very easily corrupt the file and make it unusable. This is comparable to an Operating System getting corrupted from a computer not being shut down correctly (pulling the power from wall without doing a shut down).
Hope this helps.
May 02, 2010 | Western Digital My Book Essential Edition...
''ERROR ON LOADING THE OPERATING SYSTEM''
ur boot file are corrupt...
or ur main OS files that load Win is corrupt....
re-format and load OS
u need a Win OS disk to install.
Dec 28, 2009 | Computers & Internet
Windows message always appears when computer starts up this is the Message (rtutils.dll is missing therefore windows needs to close)
To get rid of the rtutils.dll you can try the steps given below.
Turn on the system in safe mode by pressing F8 as soon as you turn on your system
Check the recycle bin to see you hav accidentally deleted the file. If so restore the file from the recycle bin.
If you have cleared the recycle bin then the best option would be to use a file recovery option. A software called Recuva is available. It is a file recovery software.
Sometimes the file could have been corrupted bya spyware/virus/malware. In this case run the anti-virus and anti spyware. This can help you detect the malware and restore the file back to normality.
else try to do a system restore
XP->
Start-> Programs-> Accesories->System tools-> System restore
Vista->
Click on windows (left side bottom) -> Type (System restore) in start program bar-> and click on the same.
If you are facing the problem after a software installation then try to uninstall the software and check for the error.
Try to clean up the registry
Try to update the drivers.
and if all of these don't work then try to download the dll file from the internet.
Jul 10, 2009 | Acer Aspire One PC Notebook
Configureation error
Take it back to the shop - there are 3 parts to the firmware in thoses phones:
1) Main firmware
2) File system
3) Custom pack
The "configuration error" message means that the custom pack wasn't loaded - and as a result the startup code can't figure out how to configure the phone.
If the old CDA is still in the phone, then you can try using the update service software on the SE website - but that often fails to identify the phone when it's in the state that your phone is.
Jul 02, 2009 | Sony Ericsson K750i Cellular Phone
System Error &H80004005(-2147467259) error in ms2007 pro excel and word
to correct this pls follow this procedure:
-close the file or presentation then reopen it
-open the corrupted presentation then click save as on File menu
-in the save as , pls type list, click the ff format (*ppt)
-in the file name box, type the file name you want to use, then click ok
-close and reopen the presentation
hope this helps
Aug 08, 2008 | Microsoft Office Professional 2007 Full...
LG KG-800 with Mac OS X (eject issues)
First scan your mobile with anti virus and then format your mobile next connect and add files and close all the programs running and refresh your system and then click eject or in taskbar click on safely remove hardware and disconnect it.
Aug 10, 2007 | LG KG800 Cellular Phone
Nokia 3250 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
