Pin connections on the motherboard of Acer Aspire AX3200-U3600A
I bought a new case and I can't figure out the pin connections from the case to my motherboard to get my PC running again. I'm not sure what the type of motherboard is in my PC. I have everything else connected except the power switch, reset switch, h.d.d led, +p, -p. If you can figure this out I would appreciate it so much. Thanks.
  • 52 Answers
You'll need to know the model of your motherboard, and search for the motherboard manual in the internet if you don't have one.. in the manual search about the power pin connections and you will see where to connect those wires into the pin..TY
Posted on Dec 05, 2008
"da061 078l"
Why do you need the pinouts?
Make a drawing and notes BEFORE removing any cables.
Post back in a Comment.
Feb 04, 2013 | Acer Computers & Internet
I bought a new case fan to replace an HP Compaq DC5100 Case Fan. The problem is the fan I bought has a 4-pin molex connector which I didn't find in my computer. Is there a converter from the 4-pi
You will find 3-pin to Molex only as the 4th pin is for control which older Molex does not support. You bought the wrong model fan for your motherboard. You might consider rewiring it with the old connector. See e.g. which provides wiring logic.
Jan 09, 2013 | Computers & Internet
Broken stereo output jack acer aspire 5742
These are normally soldered to the motherboard. The only way to repair is to open the case, find where it connects to the motherboard and solder it back on. If the pin inside is broken you will need to try and get a new jack socket to solder on. Can be done, but fiddly job and may be quite expensive at your local PC repair shop.
Apr 02, 2012 | Acer Aspire 5742 Notebook
How do i access recovery if my acer aspire ax3200-u3600a won't boot up
Gail, you are needing to reinstall your operating system to gain control of the system. once you reinstall OS, your files will be placed into a windows.old file on your c:/ drive. hope this helps. ps. if have dont care about what is on the hard, reformat it if possible. plus you can buy a second harddrive and install OS on that and change that drive to your primary drive. your files will be accessible through drive d:/ unless its a laptop. sorry
Oct 15, 2011 | Computers & Internet
I have an aspire M5640 and I upgrade my video card so I had to upgrade PSU to 550W and my sistem frezzes on boot? What can be the problem? Thanks
Make sure you have securely connected both the four pin and 24 pin motherboard power connectors into the motherboard. If either one of these are even partially unplugged it can cause your system to freeze. Also, since you have been working inside the computer, try pushing the RAM in, just in case it came loose. If you are still encountering problems check all the rest of the power and data connections inside your computer including hard drives and the new video card.
Apr 22, 2011 | Acer Aspire m5640 PC Desktop
I am about to switch out the motherboard for m5640 aspire 1
New motherboard will have a picture of the pin connections and where they connect on the motherboard. Just follow these connections, also the wires leading from the from the front of the case to the motherboard are labelled as to what they connect to. As a final note, the white wire on the connectors is usually always the ground wire, so look at the drawing carefully to see which side is the positive and make sure that the coloured wire goes to the positive side not the white.
Dec 18, 2009 | Acer Aspire m5640 PC Desktop
I can't find out how I can put the DVI cable in my Acer Aspire X3200. There has to be an opening but I don't know how to open it.
HI! this is the specs of your video: Integrated NVIDIA® GeForce® 8200 graphics
Discrete NVIDIA® GeForce® 9300GE graphics
VGA and HDMI™ (High-Definition Multimedia Interface™) ports
TV tuner (select models only)
Aspire® X3200-B3530A: 22" LCD ..
this are the interface ports:
FireWire® (IEEE 1394)
Two PS/2®
Five audio
Nine USB 2.0 (five front, four back)
AX3200-ED5600A, AX3200-EF9100A only: DVI-D (graphics card), optical SPDIF
AX3200-EF9100A only: eSATA
AX3200-ED5600A, AX3200-U3792A only: RJ-11 modem
DVI-Digital - is a 24 pin digital DVI you can find that at the back or infront of your pc.. if there is a cover, try to push the door to open it..
Aug 12, 2009 | Acer Aspire X3200 PC Desktop
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Led pins
I think you will have the an instruction manual of Packard Bell imedia 5106.In the manual an outline of the motherboard will be given.Figure out power and reset pins in the diagram given.
Usually the pins are at the corners only.
There will be labels near the pins like pwr rst etc.
Try connecting in the same configuration.
Please Rate me ;-) >Karatela
Dec 07, 2007 | Intel Motherboard
Computers & Internet Logo
453 people viewed this question
David Payne
David Payne
