Question about Panasonic Lumix DMC-LS1 Digital Camera
Switchs on, zooms in and out and asks to be switched on and off
When i switch on the camera the lens zooms in and out several times, when it goes back in a messege comes up on the screen asking for the camera to be turned off and on, is there a reset button??
SOURCE: Buttons stopped working
If yours still zooms in all the way when you turn it on, then I had a similar problem with mine. When I turned it on, the camera would zoom out all the way and the other buttons wouldn't respond. If I switched it to review, it would just cycle through all the pictures, so I figured somewhere the zoom lever was stuck inside. I don't know a lot about cameras, so I sent it in to Panasonic (it was still under parts warranty), but was informed that due to "grit substance" my warranty was voided and it would cost $179 to repair. Since I could buy the same camera used at for that price I told them to send mine back and I'd take a shot at fixing it (since I was pretty sure it was a mechanical problem). Here's what I did with a $1.79 glass repair screwdriver. Remove the battery and take out all the visible screws on the outside (2 on the right, 1 on the left, 3 on the bottom). Lift the back panel at the bottom edge, and it should pivot along the top edge until you can remove the back. Then unplug the two ribbon cables (the small one has a latch on top and the larger one has a black latch on the side that you need to lift). BOTH have hinges, not just the smaller one like other posts have said. Next you need to remove the front panel. There are three silver screws placed around the lens unit (look down inside, and you'll see them attaching it to the front panel). Remove these, and you should be able to remove the front (lift at the bottom and it pivots along the top edge). Now you should be able to pop off the top cover (with the zoom, power, etc). Now if you look at the bottom, there are two screws holding the board to the cover, remove these and you've got it apart. On the top right side of the board, you'll see where the external zoom switch pushes a very small black lever. This was where the problem with mine was, the black lever was stuck over. You can use the tip of the screwdriver to pop it back to the center position. Now make sure that if you push it one way or the other that it will recenter on its own. Mine didn't, so I had to pop the small silver cover off where the lever is with the flathead tip of the screwdriver. Be careful here. The lever just sits on a peg, and has very small gears that move a slide bar. If either of these fall, you may never find them again. I took both the lever and the slider off, cleaned them, and got it so it would recenter easily again. Then I put them both back in, popped the cover on (you may have to pry out one of the sides slightly to get it back on), and the lever works fine now. I wouldn't be surprised if your camera has this same problem. If it's something else, it's still probably a problem with this mechanism that you could fix. Anyways, reattach the board to the top cover, and pop it back onto the camera. Now insert the battery, and turn it on to see how it works. Even without the screen, you can try the zoom. If it all works, then all you need to do is put it back together in the opposite order you took it apart. When reattaching the LCD ribbon cables, make sure the hinges are open, insert the cable, and snap down its latch. Hopefully that works. I don't know much about cameras, but it wasn't too hard. Just work slowly and carefully.
Posted on Aug 19, 2007
  • 189 Answers
SOURCE: Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Posted on Jan 03, 2008
SOURCE: Panasonic Lumix DMC-FX01 Less than 1 year old
same problem with ours, only 7 months old. We returned to the seller under warranty, and they fixed the problem FOC. They stated "lens adjustment" on the repair invoice.
I think these machines are not as sturdy as we are led to believe, and the slightest knock or bump sends them a bit squew wiffy!
Posted on Jan 25, 2008
SOURCE: Panasonic DMC-TZ1
I just had this problem, too. I basically disassembled the camera by removing the back cover, front cover, and top assembly. The top assembly includes a plastic part between a circuit board and the top external metal piece that houses the button on the top of the camera. On the circuit board there is a switch for the zoom that looks like a pinball flipper. You have to make sure that it's working properly and you may have to remove the metal dust cap and remove any sand if it's lodged in the mechanism. It's pretty tough if you're not good with your hands because it's extremely small. I did this and the zoom began working like normal again, but then I got the message that the camera needs to be turned on and off every time I turn on the camera...
Posted on May 14, 2008
  • 98 Answers
SOURCE: Stuck Lens
It seems that the lens is stuck.
If you can repair it i have the repair manual, if not i can repair this problem, I'm not shure if i allowed to send our repairadress in the Netherlands we replaced a few gears or repair the damage into the lensunit.
Posted on Apr 05, 2009
SOURCE: The zoom switch of my Lumix dmc-tz1
I found an adress where I can buy that switch.
Thank you for your help.
Best regards, Harrie van Schalen
Posted on Nov 18, 2009
0 characters
1 Points
How to fix a Fujifilm FinePix S4000
some times small particles or grit get into the lens housing and prevent movement... try holding the camera vertical with the lens pointing down and tap the back of the camera firmly a couple of times... keep the camera in this postion and switch the camera ON and OFF a couple of times to try and loosen any foreign particles... you may have to repeat this procedure several more times before you achieve success...
Apr 04, 2016 | FUJIFILM FinePix S4000 / S4050 Digital...
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Fixing a seized AF motor
One theory on this is that the camera's software or settings may somehow be corrupted, so you should go through the process of resetting the camera to its original factory settings. If that does not clear up the problem, try another AF lens and conform whether the problem is the lens or the camera body. If the camera is not focusing another lens, then you may need to clean the contacts or look for some sort of damage.
If it turns out that it is the lens, the best solution is to send it to Tamron for service and see what they can do about it.
If you cannot send it to Tamron, you ought to see whether it is something as simple as some sort of internal dust or dirt collection blocking the mechanical switches and functions of the lens.
Start with making sure that you have a fully charged battery for the camera or AC power adapter for the camera. You do not want any of the problems with the camera to be related to having too little voltage available.
Make sure that the camera's power switch is switched off. You do not need to have the battery or adapter connected just yet.
Next, with the lens off of the camera, switch back and forth several times, firmly, between AF and MF and switch the vibration compensation off and on a few times. Of course, do not drop the lens. Also, unless you need the zoom ring locked, you may want to make sure that the zoom ring lock is fully off. While you are doing this, or after switching back and forth, check the electrical contacts on the lens and the camera body. If anything looks even a little less than shiny, clean the contacts.
With the camera's power still switched off, put the lens back on the camera.
Either put the battery in the camera or connect the AC adapter.
Set the lens to AF with vibration compensation off.
Switch the camera's power on.
Try getting the camera to automatically focus on something. If it works, turn the camera's power off, then switch vibration compensation on, then turn the camera's power on and try again. It may be fixed, at this point, which means that you can ignore the rest. Otherwise:
Turn the camera's power off again and switch to manual focus. Turn the camera's power back on and rotate the lens's focus ring (gently) all of the way through the focal range two or three times. Try taking one or two pictures, just to be sure that everything is working in manual. Turn the camera's power off and switch the vibration compensation, then turn the camera's power back on. Gently rotate the focus ring all of the way through the focal range two or three time, and then take two or three pictures to verify that everything is still working in manual.
After that, turn the camera's power off and switch back to AF with vibration compensation off. Turn the camera's power back on. Try to get the camera to automatically focus on something. If it works, then turn the camera's power off and switch vibration compensation back on again. The turn the camera's power on and try to get it to automatically focus on something.
If all of this works, than you should be okay with it as it is. You may still want to send the lens in to Tamron to get it serviced, in case the problem was some sort of lint or dirt getting caught up in the gears or servo that moves the lens through the focal range.
If it does not work, you could try to force the lens to re-engage the autofocus servo. It will probably void your warranty, if you still have one, so you are better off send it in to Tamron for service, first, before trying it. Also, as the manual and common sense would indicate, if you try to force the lens to adjust its focus ring while it is switched to AF, you could easily break the mechanism in the lens.
With that being said, some people claim that they got their lenses to return to proper autofocus by leaving the lens switched to AF and trying to rotate the focus ring manually. One person says not to "force" it, his just took a "firm push". I have not tried this, so I do not have advice on how much force may work or how much will damage the plastic bearings, gears and teeth inside the lens.
May 04, 2014 | Nikon D60 Digital Camera
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
Zoom error
reset camera but it would appear that the lens is not functioning properly and would need repair
Sep 06, 2008 | Olympus SP-550 UZ Digital Camera
V570 Dual Lens, will not switch to ordinary lens.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
Jun 10, 2008 | Kodak EasyShare V570 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera dropped, won't zoom in or out, won't take pics
it has detected a mechanical restriction that is severe enough for the micro to "time-out" and shut down to prevent further damage.
Jun 03, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Try for a repair Mark but I feel that it is probably to be considered beyond economic repair - the price will be pretty near a later one
May 25, 2007 | Olympus Camedia C-2040 Zoom Digital Camera
Panasonic Lumix DMC-LS1 Digital Camera Logo
29 people viewed this question
Top Panasonic Digital Cameras Experts
Level 1 Expert
Are you a Panasonic Digital Camera Expert? Answer questions, earn points and help others
