Question about Kenmore 62622 Electric Dryer
My Push Start Relay or Control Knob is not starting the Dryer
I turned the dryer on yesterday to find that it automatically stopped on it's own. When I tried to restart it by pushing the control knob, it wouldn't work. We then proceed to remove the top off of the dryer so we could see the underside of the control panel. We assumed maybe some fuses were bad but didn't have time then to really work on it. I came back to the dryer yesterday afternoon and looked again, turned my time dial (which lit up and started ticking) and hit the control knob. It worked. I continued laundry for the next few hours. Late last night after I had loaded my last load, the control knob ceased to stop working again. I thought maybe I should let it cool down but as of this morning...still no luck. I am assuming that it is the control knob that is defective but I have heard that this is rare. I am not sure what to try next. Any suggestions??? Thank you. P.S. I have an Electric Kenmore Dryer. Model # 62931.
  • noheatpete Aug 30, 2008
    my kenmore electric dryer model 68972 push start button will not turn on the dryer unless it is held down
  • Anonymous Mar 23, 2014
    Dryer starts fine and runs fine. Control knob does not advance so dryer does not shut off.
  • 67 Answers
Is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Posted on Mar 21, 2007
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Push in knob to start dryer. The dry starts, but when I remove my finger off the knob the dryer stops running. Only runs when I hold the start knob in. Kenmore Model: 110.64982300. What is happening,...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Dryers
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
When I push the "push to start" button (knob) on
heatman101
Mar 14, 2011 | Kenmore Dryers
DLG330RAW Gas Dryer: no power when I push the knob to start drying...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
May 07, 2010 | Amana DLG330RAW Gas Dryer
Broken Start Knob
You can buy this switch from ap wagner for $24.50
Go here and put in your model number, and the parts list will come up
http://www.apwagner.com/
May 21, 2009 | GE Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
Kenmore 62622 Electric Dryer Logo
406 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
