I have a microphone KOSS M20BK and i want to use it but it wotn detect it on my computer. I was wondering if you have a software that i can use in order to get my microphone working?
  • skippymac20 May 11, 2010
    Is the mic powered or does it require phantom power?
  • Arthur Aldrich
    Arthur Aldrich May 11, 2010
    What kind of PC?
    What kind of audio capture software?
    Sound card built in or USB sound card that plugs in?
    Need to know these particulars.
How to connect microphone
Make sure microphone is compatible with your computer.
First find the port for audio jack on your computer. In case of PC, it is located either on the front or back side of the CPU. In case of laptop, check all the sides of laptop.
Once you find the suitable port, try inserting your microphone's connector into that port. If your microphone have 2 connectors, that is headphone and microphone combo, you'll have to find such port on your computer. If you cannot find suitable port, I am sorry, you won't be able to connect microphone.
Lastly, you need is drivers which will be automatically installed if your computer detects your microphone. Now your microphone is ready to use.
Hope this helps.
-Meet.
Oct 06, 2013 | Computers & Internet
Koss SB45 Professional Headset front jack doesnt work
Sounds like the jack on the front of your device is not working properly. Do other headsets work in that jack or no?
Mar 25, 2012 | Koss SB45 Professional Headset
I receieved a pair of Koss SB145 headphones without the instruction manual. It has two connectors and I am clueless how to record things etc..
I suspect that you actually have the Koss multimedia headphone/microphone model SB/45 as shown on the right earcup, not SB145.
If this is the case, the 3.5mm connector with the black plastic (contains a headphone symbol molded into the plastic) and red insulation bands separating the conductors is for the stereo headphones. The other 3.5mm connector with the tan plastic (contains a microphone symbol molded into the plastic) and black insulation bands is for the microphone.
You need to plug these into the microphone input and headphone output connectors on your computer or whatever device you are recording with. Then adjust the microphone input audio level and headphone output audio level on your recording device. Consult your manual for your recording device to locate the correct connectors and for instructions to adjust the audio levels.
Also, be sure to check and adjust the volume level control on the headphone cord if you don't hear anything after correctly connecting them to your recording device and adjusting the levels.
Aug 14, 2011 | Audio Players & Recorders
Microphone Not Working
Try right clicking on the speaker icon on your system tray. Make sure that the mic volume is not on mute.
Jun 03, 2010 | Koss (10-16-004) Headphones
Microphone not working. running windows vista. I've looked everywhere online and all the settings I keep seeing people say to change don't show up on my computer. Also says all the drivers are up to date.
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Try to download and install it, hope it helps.
Feb 22, 2010 | Koss M5 Lapel Mic with Adhesive backed...
When I plug in my Logitech USB Desktop Microphone into a usb port on my computer it does not detect the new software, how do I fix this so I can install it?
Sometimes you have to install the drivers and software before you plug the microphone in and sometimes it is the other way around.
Jan 20, 2010 | Logitech USB Desktop Consumer Microphone
I have been told my Koss DVD Player needs a Firmware update and I am wondering where I can find this online?
It is available at this site:
http://www.videohelp.com/dvdplayers/koss-kd365/2886..............sodeep
Oct 26, 2009 | Koss KD365 DVD Player
My mic aint working
most likely a broken wire inside. it's dead imo.
Apr 14, 2008 | Koss SB45 Professional Headset
Can't detect the mic on software
What is the make and model of the firewire box you are using?
Jun 18, 2007 | MXL 990s Professional Microphone
198 people viewed this question
 Grubhead
Grubhead
