Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Won't come on
Just purchased a new Kenmore canister vacuum. Used it some once. I was using the stick attachment for the first time to get up some ants. I stood there holding it for a few minutes to make sure I got them all. Then I went to vacuum out a window and accidentally caught a plastic bag, but pulled it away from the vacuum within two seconds. Now, I can't get the vacuum to come on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
The guest is right,but also check the brushes, make sure nothing else is there. and don't forget to clean out the bearings every so often.
Posted on Feb 07, 2008
Try pushing the belt reset button. I've had it work for the stangest things.
Posted on Apr 10, 2007
Wheel is sticking. I want to remove the wheel to clean the axel. kenmore 116.27514700
Thanks for the clarification. This is actually fairly simple to remove the rear wheel, however as you'll see after this has been removed, there really is no axle attached to this. It just snaps into the main canister housing. It may be that your wheel has broken, and a new wheel may fix your problem.
First here's a link to the parts shematic for your model so you can follow along:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11627514700&productCategoryId=0642000&brandId=0582&brandDescription=KENMORE&modelName=VACUUM-CLEANER&diagramPageId=00001&componentDescription=CANISTER&documentId=P0706048&blt=06
Simply put a flat head screw driver behind the brush, and pry it off. It will easily come right off. You may inspect the wheel, and the wheel housing that it snaps into to make sure there are no obstructions, or pet hair that are slowing the wheel down. Also look at the clips that hold the wheel in place to make sure there's no debris above the clips on the wheel that could slow down the brushes also.
If it all appears to be fine, you may spray some WD40 on the part of the wheel that spins, reinsert it back in the vacuum cleaner and test to see if that fixes it. If it didn't, you might just want to purchase a new wheel assembly.
Here's a link to the rear wheel for Kenmore canisters if you'd like to purchase a new one from our website:
http://www.govacuum.com/kenmore-panasonic-canister-rear-wheel-assembly-panasonic-part-ac99caktzv07-sears-part-4370702.html
Hopefully that helps you. If you have any questions about how to repair this, or other questions that I did not address, simply just add a comment as you did last time, and I'll be more then happy to answer any and all of your follow up questions.
If you found this repair helpful, please be so kind and rate my repair, or leave feedback. This is really appreciated, and one of the reasons that Fixya repair professionals continue to post free repair advice on Fixya.
Chris Jones
GoVacuum.com
Apr 27, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
Hi, I have a canister Kenmore vacuum with power head. Everytime I use it, it smells sour. Its strong and like FEET with bad odor. My old Kenmore did the same thing but I used it anyway...because the power...
Never heard of this odor but if you have had it in both vacs it might have something to do with a disintegrating rubber backing on a carpet.
Arm and Hammer makes a baking soda based vac powder that will help eliminate some odors.
Do several things , get the powder and pour a tablespoon of it or baking soda into a fresh bag. Keep your filters fresh. If you use washable filters be certain they are thoroughly dry before reinstalling. And use a Mutli ply filter bag.. and NEVER pick up anything wet or vacuum a damp carpet
Sep 10, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Jul 30, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
97 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
