Question about Emerson EWL3706 37 in. LCD Television
My emerson tv standby light is on the power light flashes twice
The standby light on my emerson tv stays on when i try to turn the tv on the power light flashes twice then it goes right back to standby
  • 2 more comments
  • redfive26 Jan 23, 2009
    my emerson 32" LCD wont power up it flashes then stays in standby mode...
  • cheryljdobso Apr 24, 2009
    i have the same problem i was wondering if you were able to solve it?
  • brad_crui
    brad_crui Jan 22, 2013
    same problem with me, the light stay in blue color and keep on flashes i turn it off or on but the light stay d-same blue color an fllashes
  • Anonymous Mar 29, 2014
    attempt to turn on the tv, power light flashes 14 times displays no picture or any functions.. any thoughts?
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
I have this problem too with my 32 inch Digital LCD TV.
Posted on Dec 05, 2008
    New Friend:
I have a similar problem I have a 50 inch Emerson TV that I bought less than a year ago there is a red light on the bottom front of the TV when I try to turn the TV on the light goes out its like its losing total power I can unplug it and wait a little while plug it back in and it will workbut it keeps repeating the same thing over and over so I called Emerson and they are sending out a repairman at the end of the week
Posted on Aug 10, 2014
Emerson TV not working
The capacitors on power board must be changed oth
Aug 02, 2016 | Emerson LC320EM9 32 in. LCD HDTV
Emerson TV
Check capacitor on power board they must be changed 1st
Aug 02, 2016 | Emerson Televison & Video
Power on flashes twice then shuts off
No. i think you have a power problem the switching power supply of your tv is damaged. But you can try to reset it if you know how.
Oct 18, 2017 | Emerson CR202EM9 TV
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
Emerson lc320emx trouble turning on
You probably have an internal power supply problem
Mar 04, 2013 | Emerson LC320EM9 32 in. LCD HDTV
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
Green light flashes twice then turns red
Please ignore the first solution as that blink code definition is for a Sony CRT based set, NOT an Emerson.
Carefully examine the LCD panel itself with a flashlight and look for small cracks. Based upon your description of events, I think that the panel is actually cracked. This usually only prevents a picture from showing. The red lights are an indication of an internal problem and the set is in shutdown to prevent further damage.
Without seeing the actual unit, I cannot make a definite diagnosis, but I would initially suspect a power supply problem that may be relatively cheap to fix. If the set is relatively new, I'd invest in a detailed repair estimate. Post the info here from that estimate and we may be able to walk you through the actual repair.
Dan
Jun 22, 2010 | Emerson EWL3706 37 in. LCD Television
Emerson lc32oem8 32
The flashing power light indicates a failure in the power supply board of your tv. We should be able to repair the board for our standard rate of $45 plus return shipping. If you are interested in setting up a repair please use the following link to our web site: http://www.ccl-la.com/blog/index.php/service-request-form/ Our normal repair turn around time is 2-3 days.
Buddy
Corporate Computer
www.ccl-la.com
Mar 08, 2010 | Emerson LC320EM8 32 in. LCD TV
Standby light is on but tv won't turn on/stay on
The standby light is on. When i try to turn on the tv the power on light flashes a couple of times then goes back to standby...
Jan 03, 2010 | Emerson LC320EM8 32 in. LCD TV
Emerson EWL3706 37 in. LCD Television Logo
5,695 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
