Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Replacing Lamp Panasonic TVPT-50DL54J (LAMP#TY-LA2004JS)
I purchases a remplacement lamp for the above TV, there was no instructions with the lamp on how to replace it. In the manual it says refer to instructions accompanying lamp.
Can someone help me step by step or where I can retrieve instructions on how to replace the lamp.
Thank you
Natascha
    Genius:
  • 1,239 Answers
HI As a safety factor replace the power board
and replaced lamp cleaned ducts. VerifY all fans are working. TV powers up with all normal led indications. Projector lamp is on bright.
Audio works from all inputs.
IF you have any doubt call JVC help.
or try customer care at +1-201-392-4571, samuelsj@us.panasonic.com
+1-201-392-6124, saferw@us.panasonic.com
Posted on Dec 04, 2008
  • 51 Answers
The instructions are indeed SUPPOSED to come with the lamp. Sometimes that is not the case.
Call panasonic customer care @ 905-624-5505 with the part number of the lamp and they can probably mail or fax the instructions.
    Genius:
  • 1,550 Answers
You can get information from the service manual below
Service manual
    Genius:
  • 3,422 Answers
HI,
Please click on the below link for the instructions to replace the lamp:
http://www.dlptvreview.com/dlptvreviews/projection-lamp-replacement.html
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
TV does not start and lamp light flashes red
Your lamp has gone out. here is a replacement for it,
http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001
i would pick the more expensive one as it is from Panasonic and will have way more life then the cheap Phillips replacement.
Replacing the lamp is easy. Here are instructions.
http://www.fixyourdlp.com/manuals/Panasonic/TYLA1001.pdf
Aug 27, 2010 | Panasonic PT-52LCX66 Projection Television
I am about to replace a DLP lamp. How do I reset the lamp time on a Panasonic PT-50DL54J, using a TY-2004 lamp?
This all probably comes a couple years too late, but when you install a new lamp, you’ll want to reset the hours on the counter your television has. Doing this will allow you to avoid getting any messages about the lamp needing to be replaced despite you having a new lamp inside your set.
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Jan 31, 2010 | Panasonic PT-50DL54 50" Rear Projection...
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
Pt-50dl54j after replacing the lamp i get a flashing green
chec to make sure lamp housing is in all the way make sure screws are tight.
Dec 17, 2009 | Panasonic PT-50DL54 50" Rear Projection...
No screen at all, does not come on.
If you haven't replaced the lamp yet, that is the first thing to try. Its not hard to do at all.
You can get the lamp just about anywhere on the web.
Here is a link to one site
Here is the procedure for replacing the lamp.
Unplug the unit from the wall and wait for all the lights to stop blinking. Ensure that the lamp and the area around the lamp has cooled.
Remove the front cover of the set. You should be able to see the lamp door at this time, loosen the screw and remove the door. You will now have access to the lamp, loosen the lamp screws and remove the lamp cartridge. Reverse the above process and you should be back in business.
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 23, 2009 | Panasonic PT-52LCX66 Projection Television
Reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Feb 19, 2009 | Panasonic Televison & Video
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
