Question about First Alert 7-day Vacation Timer Home Security Safe
I have the first alert with the black white black white colors and little pegs, white is to start black is for off,,, I cannot get it to start any suggestions
How do you set it up
http://waterheatertimer.org/How-to-set-timers.html
analog timer instructions
pegs are installed on outer edge of dial for on-off operations
Gene
Aug 27, 2014 | First Alert Tm261 7Day Vacation Timer
Dell projector 1800mb blank display or white display
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Feb 01, 2014 | Dell Office Equipment & Supplies
COLOR GOES TO BLACK AND WHITE
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Oct 21, 2013 | Samsung - Lamp for Samsung HLR4667WAX/XAA...
Aaer p1101 dlp projector has vertical lines during projection
Oct 03, 2013 | Acer P1101 Compatible Projector Lamp
My little 15
If the format of color system such as PAL/SECAM etc. is not same as that of telecast, you will get picture in black and white.
Aug 04, 2012 | Coby TFTV1503 15 in. LCD Television
I bought Master mind for kids game, made by pressman. It did not come w/ any instructions. I need rules for the game to play the game.
The two players decide in advance how many games they will play, which must be an even number. One player becomes the codemaker, the other the codebreaker. The codemaker chooses a pattern of four code pegs. Duplicates are allowed, so the player could even choose four code pegs of the same color. The chosen pattern is placed in the four holes covered by the shield, visible to the codemaker but not to the codebreaker.
The codebreaker tries to guess the pattern, in both order and color, within twelve (or ten, or eight) turns. Each guess is made by placing a row of code pegs on the decoding board. Once placed, the codemaker provides feedback by placing from zero to four key pegs in the small holes of the row with the guess. A colored (often black) key peg is placed for each code peg from the guess which is correct in both color and position. A white peg indicates the existence of a correct color peg placed in the wrong position.
If there are duplicate colours in the guess, they cannot all be awarded a key peg unless they correspond to the same number of duplicate colours in the hidden code. For example, if the hidden code is white-white-black-black and the player guesses white-white-white-black, the codemaker will award two colored pegs for the two correct whites, nothing for the third white as there is not a third white in the code, and a colored peg for the black. No indication is given of the fact that the code also includes a second black.
Once feedback is provided, another guess is made; guesses and feedback continue to alternate until either the codebreaker guesses correctly, or twelve (or ten, or eight) incorrect guesses are made.
The codemaker gets one point for each guess a codebreaker makes. An extra point is earned by the codemaker if the codebreaker doesn't guess the pattern exactly in the last guess. (An alternative is to score based on the number of colored key pegs placed.) The winner is the one who has the least points after the agreed-upon number of games are played.
Jul 19, 2011 | Video Game Consoles & Games
How should I connect the wires to the motors? Our Peg Perego John Deere tractor lost its ability to go. I saw voltages on the motor wires when the wires were disconnected from the motors, but no...
white and black on one motor and red and blue on the other motor you can change which way the wheel spins by swapping the two wires around on the motor
Oct 16, 2010 | Peg Perego John Deere Turf Tractor
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
Lost bios pas word help
should be a little jumper somewere next to the batteri on the mohterborad it eather blue,white or black , should be three little pegs were ever they are set move the peg to the right and restart your computer it should say bios reset then turn off your computer and move the peg or jumper back to were it was
May 02, 2008 | Computers & Internet
First Alert 7-day Vacation Timer Home Security Safe Logo
Top First Alert Hardware & Accessories Experts
Gene Haynes
Tom Chichester
 Mikey
Mikey
Are you a First Alert Hardware and Accessory Expert? Answer questions, earn points and help others
