My Hikona DVD player (TDTV-1001) won't open the disc tray. I can hear a whirring of something trying to do something, but the tray won't move. Any suggestiond?
SOURCE: sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Posted on Jan 18, 2007
SOURCE: dvd tray won't open
the belt that opens and closes the drawer is too old and likely stretched out or otherwise deformed..
it's a $3.00 part however i'm having difficulty finding the part number to find an exact match, and could use help on that.
i'm going to temporarily use a belt i got from a dvd repair place. we measured it and found one that's ALMOST the same size (little skinnier but little shorter. difficult to gauge proper belt without a parts list.
i'll keep looking.
if anyone has access to parts list for GoVideo DVR4200 i'd appreciate the heads up.
Posted on Nov 02, 2007
SOURCE: Conia M580 DVD player has
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Posted on Nov 30, 2008
Testimonial: "Many many thanks for your help - your instructions were dead-easy to follow and I've now successfully rescued my much-prized "Black Books" DVD disc!!!"
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
  • 65 Answers
SOURCE: LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
Posted on May 21, 2009
Pioneer dv-2010 dvd player makes a whirring noise
That's because the lazer on the tray is trying to read the disc. Does this happen to other discs? When the lazer can't read the file, the drive spins up the disc to help it read it.
Dec 09, 2013 | Televison & Video
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Dvd drive is not working
Replace the DVD drive. They are inexpensive and it's not worth your time to try and fix this drive...
Feb 05, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
In the middle of playback the picture suddenly
Lens of the disc player needs to be cleaned.
Jul 06, 2009 | Pioneer DV-410V-K DVD Player
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
Aug 20, 2008 | Samsung HT-WP38 System
Panasonic dvr,
If you hear the motor whirring then the drive belt may be broken. Pushing the buttons will not work. Someone will have to open it, remove the disc and replace the belt (if it's broken).
Feb 17, 2008 | Panasonic DMR-ES10 DVD Recorder
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
