Question about LG LS-K1830CL Cool Mini Split Air Conditioner
HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
I HAVE AN AMERICAN STANDARD HEAT PUMP/AIR CONDITIONER UNIT OUTSIDE MY MOBILE HOME. THE UNIT IS LESS THAN A YEAR OLD. LAST WEEK IT SMELLS ONLY WHEN THE A/C IS ON
WHEN HEAT IS ON IT DOES NOT SMELL UNLESS IT GOES IN DEFROST MODE AND JUST A FEW SECONDS THEN WHEN THE WARM AIR COMES THRU THE SMELL GOES AWAY. I HAD IT LOOKED AT AND NO ONE KNOWS WHY.
THANK YOU
I know what it smells like...a dead animal! It is not a burning smell because it happens only when Cool is on. I hope someone has a solution for this. We have changed both filters but that didn't work. And the smell comes through even when the filters are taken out.
Posted on May 18, 2013
  • 833 Answers
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Posted on Dec 04, 2008
Heat works until thermostat calls for aux heat, then blower shuts off with outside unit still running.
Some blowers shut off depending on the system. Do you have electric hest strips inside? If not the blower will shut off. The outdoor fan should not be running if in defrost mode. If you have heat strips then you likely have low voltage wiring crossed
Dec 16, 2016 | American Standard Heating & Cooling
I have American standard heritage 11 heat pump with the coils inside btw it's a double wide I was wondering where the fuse might be located
There will be a box that the unit gets power from, either up on the roof or on the side of the home, the fuse or circuit breaker will be in there.
Jul 18, 2016 | American Standard Heating & Cooling
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
American standard error code 158
thermostat error codes for an american standard ... - AllExperts
en.allexperts.com > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
Fan not running on outside unit of ac
Most likely it is a bad motor bearings. The bearings are not replaceable verify the motor is getting power and it it is replace the motor. There is a slight chance it has a bad run capacitor but not likely
Oct 22, 2012 | American Standard 5000 Heat Pump Unit
Heat Pump
That is normal. Secondary heat is not needed unless it is very cold outside. If the heat pump can't keep the house warm enough and the temps start to drop, the secondary heat kicks in. 2 degrees is normal.
Aug 18, 2012 | American Standard 5000 Heat Pump Unit
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Jan 02, 2011 | Heating & Cooling
I HAVE AN AMERICAN STANDARD HEAT PUMP/AIR CONDITIONER UNIT OUTSIDE MY MOBILE HOME A FEW DAYS AGO A UNKNOWN SMELL COMES THRU ALL VENTS IN AIR CONDITIONER MODE ONLY. WHEN HEAT IS ON THERE IS NO SMELL UNTIL...
This is a condition called Dirty Socks Syndrome air cleaners and dehumidify usually fix the problem also adding a uv light to the duct can remedy the problem the light is probally the cheapest solution
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
1,052 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
