Question about Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner
Dvd compatibility issues...
Hi, Im having a lot of problems with dvds i burn using pioneer dvd -111 drives. The dvds al play fine in my computer, and on my seperate £35 philips dvd player bought a year ago. However a lot of my clients that i produce the dvds for have problems with the dvds, where they skip, freeze, and generally dont play. It seems they also seem to deteriotate, in that they wil play for the first few times and then start to get worse to the point where you cant watch them. I am at a loss as what to do, they work for me when i send them out, so how can i make dvds that are good for everyone. I record the master at 4x speed, on to verbatim dvd-r discs, though my multi burner records at quicker speeds than this. Should i always record at 4x. should i be using dvd+r? is one format better than the other? Would very much appreciate any help anyone can give. Thanks Steve Jay
  • steve jay Feb 08, 2007
    Thanks for that mate, will download the firmware now. I also have been talking to people about the maximum bitrate used on my dvds, wheer some older dvd players might not be able to keep up with high bit rates.
    I have been told to try with encoding with a maximum bit rate of 6000, as this should be low enough for many players. Does this sound right?
    Novelist:
    Champion:
  • 202 Answers
You should try updating the firmware in the burner. http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=16989 http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html scroll down a page or 2 and you will see the firmware upgrade for your model. Good Luck, Tim
Posted on Feb 08, 2007
  • Timothy Higgins
    Timothy Higgins Feb 08, 2007
    Steve: Yes, I was also going to type a whole bunch about the variety of DVD players/burners that your clients have some better, some worse. The firmware update info list seemed to address some of the problems you were having i.e. backward compatibility. Also, Try to make sure your clients are using DVD players(when available) and not another burner to read the disc...as burners are just that...They burn. They aren't made for reading they are made for writing. And like a jealous auther they won't read what others write.
    Tim
SOURCE:
I'm using a Dell Inspiron 1300 Laptop with an NEC DVD+-RW ND-6650A CD/DVD reader/writer. Also using Showbiz DVD2 to burn backups of VHS tapes I can create single layer DVDs fine. However, when I try to...
how long is the whole process of burning the dual layer dvd's
your computers hard drive might be getting to hot
try blowing out all of the dust from your laptop computers keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of unforseen problems with a computer and its parts
also you might buy a laptop usb 3 fan cooler pad just to keep things cool/er
you might check the leads ((motherboard to hard drive)) they might be bad/faulty
hope this helps
Mar 07, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
DVD Burning
Well first of all, as far as have been informed, making backup copies of dvds is illegal. But im not here to critisize you. Your discs that you are copying the movie onto might not be big enough to hold the file. And your laser in your computer might not also be up to the challenge. There should not be any problems with any discs, but you may want to try using standard dvds, not rewritable dvds.
Hope this helps :)
Jan 21, 2008 | Computers & Internet
Cannot burn dvds on pioneer k17 drive
The burning software might not have support for ur drive try nero or alcohol 120
Feb 03, 2009 | Pioneer DVR-107D DVD±RW Burner
My dvd burner doesn't burn good dvds
Have your dvd burner burning lens cleaned. This should help you!
Jan 24, 2009 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Dvd problems
you have a very sought after dvd player there.
people are paying a lot of money for these.
They Only support DVD- Disks. DVD-R/RW DVD-ROM. DVD- Video. If you are trying to Read Any DVD+ Formats, they,re not compatable with this Drive.
Hope this answers your problem.
Mike @ compurepair.
p.s recommend A Pioneer 111-112 Drive, reads most formats.
Mar 31, 2008 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
DVD R burnt by pioneer drive couldn't be read by itself.
If there were compatability issues with the disc it would have been unable to burn to the dvd initially, the problems you mention are a sign that the reading in the dvd is failing and there's never a solution for problems as these, as it means that a replacement is needed, as the dvd writer arent worth repairing. I had the same thing exactly, but after a while it wouldnt even acknowledge that i had a writable dvd in the drive, but was ok with cd's. I think it is down to poor quality lasers, so as to keep the dvd writer prices down.
May 04, 2007 | Pioneer DVR-110D DVD RW Dual Layer Burner
Bitrate compatibility issues
have you been using constent bitrate or verable bitrate and which program are you using to encode your dvd's do a test dvd with 6000 and do another at differant rates I use Ulead Movie Factory to do my dvds and use vairable bitrate as the movies are in vairable and also the regioncode for your burner has to be set for good burns as I'm in uk my dvd burner is set to region 2 and I've had no problems with dvd buning and playing on other dvd player. hope this works out for you
Feb 08, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Open Questions:
Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Logo
89 people viewed this question
Top Pioneer Computers & Internet Experts
Damen Wong
Damen Wong
Carmen Mikulic
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
