Question about Kitchen Ranges
I have a Gas range, model #PLGF389AC. I pressed the clean button and prior to the door locking, I opened it. Then the door locked, the cleaning did not start but there is error code F1 and non stop beeping. As the manual indicated, I pressed clear/off which allowed the beeping to stop for about 5 seconds and then immediately starts again without stopping. I also tried unplugging and replugging in, this did not work. What can I do?
  • 198 Answers
F1 means a bsd electronic range control
Posted on Dec 04, 2008
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Door locked
Your door lock mechanism failed. Needs to be replaced
Apr 11, 2013 | Thermador RDFS30 Dual Fuel (Electric and...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Oct 05, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
I have an old(over 20 nyears) free standing magic chef model No. 177-31DB2 range. I put it on the cleaning cycle and everything seemed to be working well. But then it seemed like there was alot of smoke so...
WHEN THE DOOR IS LOCKED ON A SELF-CLEANING RANGE, AND THE TEMP GETS ABOVE 400 DEGREES, IT LOCKS THE LATCHING ASSEMBLY SO YOU CAN'T OPEN THE DOOR AND GET SCORCHED. IF YOU FORCED THE HANDLE TO TRY TO OPEN IT, YOU BENT THE ARM OF THE LATCHING ASSEMBLY. IN ORDER TO RELEASE THE LATCH,
ONLY IF YOU FORCED IT TO THE OPEN POSITION, YOU MUST FORCE IT BACK TO THE LOCK POSITION TO STRAIGHTEN THE ARM.THEN IT MIGHT RELEASE.
IF YOUR RANGE HAS A LOCK BUTTON THAT NEEDS TO BE
PRESSED TO SLIDE THE LATCH TO THE LOCK POSITION,
YOU WILL HAVE TO SET ALL CONTROLS BACK INTO THE CLEAN POSITION AND PRESS THE LOCK BUTTON TO RELEASE THE LOCK ON THE LATCH ASSEMBLY. YOU SHOULD HEAR A BUZZING OR HUMMING SOUND WHEN THE BUTTON IS PRESSED.
Mar 31, 2008 | Kitchen Ranges
Kenmore gas range trouble
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
