I-inc firmware fix
I have the same problem with my CY199D. After their "firmware fix" does your monitor works OK? Thanks, Rob isayso2@gmail.com
I-INC CY199D EEPROM failure
Hello, The EEPROM needs to be replaced and your problem will go away. I have one and replaced it in mine and it works fine now.
Jan 22, 2010 | Computers & Internet
Adriananders
If Anyone is interested in EEPROMs or exchange repaired graphics cards my email address is bruce-anderson@virginmedia.com
Dec 24, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
I-INC CY199D lcd monitors will not turn on or off
find a electronic repair shop and ask them look up the ic number. if they they can read the program of of the old chip, they can put it on a new eeprom. somtimes the chip wont work but can still be read..
also have tried to find the board it self on a lcd parts web site? http://www.lcdparts.net/
also you may want to see if ebay may have a scratched up monitor of your or one they has a power supply problem.
Aug 11, 2009 | Computers & Internet
My web cam (Creative Labs,inc.model No Vf0330 ) is not clear work and i want its installing software
You can download the drivers you need here
http://support.creative.com/Downloads/searchdownloads.aspx?filename=WCVI_0330_PCDrv_US_1_11_01.exe
Apr 22, 2009 | Computers & Internet
HOW DO I RESET MY PHONE
Hi Rob,
Reset, you mean firmware reinstall. Download the latest firmware drivers from Blackberry.com and then install those drivers via the Desktop Manager on your PC.
I hope this helps,
Thanks.
Jan 30, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
I have sucessfully repaired three I-Inc CY199D monitors which all had the same problem.
The monitors program is stored in a 24LC16B which is a 16K serial EEPROM in a SO8 package.
The bad part is you have to remove this eeprom to program it as it is write protected on the board and you will need a serial EEPROM programmer and an uncorupted program I have all the above.
If there is enough interest I could offer preprogrammed EEPROMS or a repair service for the graphics card..
Dec 05, 2008 | Computers & Internet
The problem is the program for the graphics card is stored on a 16K serial eeprom which is used as a rom this can get corrupted which causes the problems you are experiancing.
I have repaired three of these monitors by re-flashing the eeprom with a program cloned from a working monitor all worked fine after refashing.
Now the bad news as the eeprom is used as a rom it is write protected on the board so the only way to program it is to remove it flash it with a valid program and then replace it easy if you are a surface mount expert.and have a serial eeprom programmer.
May 31, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Computers & Internet Logo
341 people viewed this question
David Payne
David Payne
