Question about Samsung 510N 15" Flat Panel LCD Monitor
Samsung LCD 510N Monitor not optimum mode error
I have found my samsung 510N monitor is working in only enable VGA mode in windows and giving "Not optimum mode " error in Windows XP so please help me/
  • 624 Answers
Paiarunk, OK, I was having a mental block for a bit. Your PC will only boot into VGA Mode, I?m assuming if you don?t Windows will crash or something. Exactly what led up to this, have you added a new video card or loaded new drivers? What operating system are you using? Let me know the answers to these questions and any other pertinent information and we?ll start working on this.
Posted on Feb 08, 2007
I have a similar problem, and I just call Samsung then they'll swap my monitor, there a fault in some of then.
Posted on Aug 17, 2007
SOURCE:
I have the same problem. I get a box with "not optimum mode. But what I need is a picture of the mainboard with the 50 ohm resistor between pin5 and pin6.
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und
Sep 14, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Half of the screen is black - Samsung SynchMaster 710N
hello
money.
220498646211
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Sep 05, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
Samsung 913V LCD Monitor--No display when vga plug plugged in
1. please check by pressing num lock or caps lock key to verify that your machine is booting up, if yes then check the cable and if after changing the display cable it doesnt show up anything, it means you have a faulty unit
2. if numlock/caps lock key doesnt work, then your machine is not booting up, please check for loose ram etc.
Apr 04, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung 710V Comes on for a second then shuts down
the fault is the backlight, Samsung has designed it as when one of the baklights are faulty the unit shuts down.
Sep 02, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 510N 15 not optimum mode
There is an issue with the microcontroller with 510N LCD monitors. Get it repaired at samsung service center.
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Samsung 710N
hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
Jan 10, 2008 | Samsung 710N V2 17" LCD Monitor
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Samsung 510N 15" Flat Panel LCD Monitor Logo
474 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
