Question about Copystar CS-1505 Copier
C 610 Error Code on a CS-1505 copier
We recently had a power surge and caused an error code 610 on our CopyStar 1505 machine. Is there a way to reset the machine without calling a service tech to fix this. It was on a surge protector.
Thanks! :)
Tracy
Specialties Inc.
Gaithersburg, Maryland
  • tcioffi Dec 04, 2008
    First of all the code is C 610 ... secondly, there is no #s to be able to enter U163 as this is a copier, not a fax.
    This is an older machine, CS 1505. Are you talking about the same machine?
  • 58 Answers
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Posted on Dec 04, 2008
What does the code c-620 mean on a cs 1505
This is a fuser related error. Either the thermostat or thermister is faulty. The error can be rest by pressing and holding down stop, start, left exposure or light. Release the keys and press stop. The display will show U000. Press 163, press Start twice. the machine will initialize.
Nov 09, 2010 | Copystar CS-1505 Copier
C-6 and 400 error code
this error is attributed to power surges. press 1087 1087 display shows U000, type 163 and then press Start, display shows CLE press Start the machine will restart
Aug 05, 2010 | Kyocera Copystar CS-1620 Black and White...
What does error code ap mean?
AP means ADD POWDER........Toner
Jun 24, 2010 | Copystar CS-1505 Copier
Error code=620
Hello sir; Follow the following steps to reset;
1, press these three keys in order and keep hold them down,"stop/reset", "start", "left copy density key".
2, press "stop/reset" key again.
3, enter 163, then press start key,
4, after they running, press "stop/reset" key.
5, press 001 to exit.
Mar 15, 2009 | Copystar CS-1505 Copier
I'm getting c-6 400 code
This is a fixing error.But it can be caused by a power dip aswell.
Try to reset it,if the error presist then there is a problem on the fixing.
To reset-Switch the machine off,open the front cover,switch the machine on again.If it shows "open cover",press the system menu counter button.press the arrow up ones to display system settings,hold the start and # button in and press "ok"or"set"
go down with the arrows untill maintenance mode is display,press ok,then enter the number 163 and press ok.
set it for exeuteand press ok.
Then the error will be cleared.
Jan 22, 2009 | Copystar CS-1500 Copier
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Error message A 400
I'm sorry to say that it's probably the death of your 1505!
It just might be too expensive to repair, the code A400 relates to the polygon laser motor, which could mean changing the whole laser assembly, or the power source board, either way it's going to cost you. BTW, the 1505 was discontinued in June 2003, what's available today has more features at 1/2 the cost. Happy hunting...
Sep 09, 2008 | Copystar CS-1510 Copier
Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Apr 03, 2008 | Office Equipment & Supplies
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Copystar CS-1505 Copier Logo
214 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
