Question about Galaxy Radios DX- 88HL Base CB Radio
Fuse blows when I key the microphone. Why does this happen?
I have a galaxy 88 and almost every time I key the mic the fuse blows. I had somebody do some work to it a long time ago so that it put more power out. I had no problems for about two years but then it started blowing fuses so I just stopped using it.
  • 32 Answers
I am pretty sure something came loose or a connection went bad, now something is shorting, possibly to the chassis. if you think you know how to open it up and work on it than do it. Or take it to a tech and have them look at it. it should be a real quick, real simple fix.
Posted on Jan 11, 2009
What size fuse u put back in it 7amp what u should have put back in it i think
Posted on Feb 21, 2009
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
Blown fuses on galaxy dx 939 after holding mike switch for less than ten seconds
try to key it down without the mic attached and see what happens.it could be in the ic or even the final so be prepared to replace them
Nov 19, 2013 | Galaxy Radios DX 939
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
Sep 25, 2013 | Galaxy Radios DX- 88HL Base CB Radio
2547 when turn on has a squeel thru the speaker in recieve mode
hi iff you remove the mic does this squeel disapear ,if so i recomend that you open mic casing and check for any lose strands of wire that could be shortening out ive seen this happen so many times with microphones you can get some switch oil and apply sparingly to switch this will also help in the long run ,,,,,goodluck with it
Feb 11, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy dx99v, bad squeal when I key the mic
Your microphone wires may be shorted take the mic plug apart (small screws) Now check for frayed wires touching or twisted together!
With the wires being resolderd or taped apart put back together
with the U pointing downward you shout have :
Right corner bottom Sheild ground!
Left corner bottom Black recive
Right corner top White or yellow this is Audio wire
Left corner top RED Transmit or PTT wire
If wiring looks good the problem is in the Mic take to servicer!
May 09, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a stock 88 and i was woundering if i could run a power mic on it and i was woundering how much for a tune up and a mod kit added to her
Yes you can add a Power Mic but do not expect a lot of positive gain from it as the Galaxy already has a Power Mic Circuit inside the radio and you will only be duplicating it at best, more that likely overdriving it. A good quality microphone like a Shure Controlled Magnetic would be a better choice. A tune upi will help emincely as these radios are mass produced and are not peaked to preformance like asuper tune will do both improving both the transmit and the recieve. Yes the Mod Kits help a lot if they are both the right ones and they are professionally installed and aligned. You can call 706 270 39829 they can help you as they are Galaxy / Ranger Experts.
Aug 03, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Radios DX- 88HL Base CB Radio Logo
310 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
