Question about Canon PIXMA iP1800 InkJet Photo Printer
My printer canon ip 1800 is not responding. I can't do anything. The lights flashes green and orange. I disconnected the printer from the computer but I have the same message ( The printer is not responding) Can you tell me how to reset the printer?
  • Anonymous Dec 06, 2008
    My printer is a Cannon Pixma iP1800 and it is flashing a green light and an orange light, and it wont pull the paper down
  • thulung Jan 03, 2009
    I got cannor IP1800. Few weeks ago ran out of both ink cartridges and recently bought and changed them but I got green and orange lights flashing it doesn't seem to work, can anyone help me, please!
I have to buy another printer ,obviously not canon.
Posted on Dec 05, 2008
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
Apr 20, 2011 | Canon PIXMA iP1300 Printer
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Ip 2000 on button flashes green then orange ,
Needs resetting at best.....perhaps it might shut down completely.....I had the same problem then my printer completely shut down!
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
Cannot get my canon to respond. Has worked fine in the past. I push to bring online and the light still blinks yellow.
Your machine does a longer green flash and then a series of orange flashes and then green again. I need to know how many orange flashes between the greens to tell you the problem..
Aug 03, 2009 | Canon S520 InkJet Photo Printer
Flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Mar 31, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
8. Your printer should respond as normal..
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
315 people viewed this question
old marine
old marine
