Question about Hunter 52" Ceiling Fan With Light And Remote Control
Fan with light (no remote) with wall switch not a 3-way
I purchased a ceiling fan with a light. (Hunter) I do not have a 3 way switch in the room, only normal light switch. Do I have to replace fan (no remote) with a fan ith a remote or can I rewire to us existing setup without a remote. tks
    Scholar:
  • 75 Answers
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Posted on Dec 21, 2008
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
My hunter fan light can't be turned on/off with the light switch
The switch will only turn the power on to the fan/light. You have to use the remote to dimm the light & change the speeds. You should be able to install it on the wall next to the switch so you can turn on your light when entering the room.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Hunter ceiling fan model 23530-300
the roll was rusted maybe .you can take apart it for checking .
ceiling light
May 01, 2012 | Hunter Ceiling Fan Remote Receiver...
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Jul 31, 2009 | Hunter Ceiling Fan Light Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Wiring a ceiling fan with a remote sensor
since you have a remote, you don't need that extra wiring for the light/fan. just wire nut it off.
the switch at wall has 2 switches but only one will work now.
Mar 31, 2008 | Dryers
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter Ceiling Fans
Unfortunatly that is a common thing with most manufactorers now a days! they are not in the service industry. make it, sell it, dump it, make a new one. and the cycle goes on and on. You may be able to find a repair person who can fix the fans for you at a reasonable cost.
Jan 18, 2008 | Oasis Hunter 54' Ceiling Fan
Dryers Logo
192 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
