Question about Car Audio & Video
CCR600 cd Multi Changer
Unit is in SAFE mode, however tuner does work. I have correct CODE to unlock unit (as used it before), but it will not work this time.
After entering code in correct way as per the maunal, the unit stays in SAFe mode! Grrrrr! Please help.
Thank you
Andrea
  • tswanwick May 15, 2009
    my philips multichanger is in safe mode the head unit works fine please help
Were could i get the tray for the chager
Posted on Dec 27, 2008
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
I cannot get multi CD changer to play CD's. Single CD in main unit is OK but no track info etc appears on screen. Also cannot eject cd's in myulti changer.
This seems to be a failure of the micro controller of the unit as it fails to identify as well as display the functions.
You will need to check he connecting cord , check the connectors and the inner voltage to the circuits.
Oct 11, 2010 | Bose Wave music system Multi-CD Changer...
WE HAVE A CD PLAYER IN THE CAR ALREADY WITH A REMOVABLE FRONT BUT ONLY PLAYS ONE CD CAN WE FIT A MULTI CD CHANGER TO THE EXISTING CD PLAYER OR DO WE HAVE TO GET A COMPLETE NEW CD SET UP
several companies have multi disc CD players that are in dash..
and others have the changer in a remote location ( trunk) and are controled by the head unit..
Which model head unit do you have? It could very well fit into the later catagory and support a remote located disk changer..
Sep 29, 2010 | Car Audio & Video
Radio code Vauxhall Philips CCR600 post year 2000
Unfortunately this CCR600 code will only be available from your Main Vauxhall dealer or by using a Radio decoding Service
It will not be available for free from anywhere on the Internet
Sorry
{;o(
May 14, 2010 | Car Audio & Video
How do you switch between the front aux and the line in on the back of unit
According to the manual:
"In the case of a CD/MD changer or SAT tuner being connected: when "source" is pressed the connected device (MD, XM, or SR) will appear in the display, depending on which device is connected. Then if "MODE" is pushed you can switch the changer or change the SAT tuner band."
Mar 24, 2009 | Sony CDX-GT520 FM / AM Receiver
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Cd multi changer
My experience with the x type is that everything that is added must be introduced to the ecu/car before it will operate. If the same is to apply for the multichanger it would have to be carried out by somebody who has the correct equipment.
Oct 02, 2008 | 2002 Jaguar X-Type
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Car Audio & Video Logo
319 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
