Question about Panasonic KX-T7630 Corded Phone
How to change the incomming ring tone on panasonic kx-t7630
My phone's current tone when ringing is high pitched an annoying. How can i change my ring tone? Any help would be greatly appreciated.
  • 4 more comments
  • cblackburn Dec 05, 2008
    Thanks Macinblack..worked great!!!
  • easot Dec 08, 2008
    The mentioned solution only works for Intercom calls. Outside calls still ring with the same tone. Anybody know how to change the ring tone for a outside line.
  • Anonymous May 07, 2009
    I also would like to change the ringtone for incoming calls from an outside line.
  • andrew_jo896
    andrew_jo896 Feb 04, 2013
    press the line 1 or line 2 buttons twice instead of intercom
  • Zadjali
    Zadjali Feb 25, 2017
    Dear I have a problem If I have incoming calls the phone will not ring the light will be flashing only how can I change it to make the phone ringing
  • Anonymous Feb 25, 2017
    Internal call there is no problem at all the phone will rings.
  • 6 Answers
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Posted on Dec 05, 2008
  • 903 Answers
Http://www.fixya.com/support/p123986-panasonic_kx_t7630_corded_phone/manual-7455/page-12
if you click on the lick there is an online manual from fixya, click on page 13, scroll down and you will be guided on how to change the ring tone.
I hope this helps
Posted on Dec 04, 2008
    New Friend:
Dear I have Panasonic KX-7730 when I received a call from outside the phone will not ring just light will be flashing anyone can guide me please.
Posted on Feb 25, 2017
    New Friend:
Http://www.fixya.com/support/p123986-panasonic_kx_t7630_corded_phone/manual-7455/page-13
TO CHANGE RING TONE
1. press PROG
2. press twice INTERCOM
3. you will see on LCD "Tone Type-01" if you dont like you can press ENTER to select the tone you prefer to set
4. press ENTER
5. EXIT
Posted on Mar 08, 2013
SOURCE:
Panasonic kx rring tone
This phone does not allow you to change the ringer tone. You can change the volume (page 18), the voicemail tone (page 36) and the incoming call tone number (page 42). For full details see the referenced pages in the manual.
Aug 06, 2012 | Panasonic KX TSC14 Corded Phone
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
Can't change ring tone on Panasonic KX-TCA175
I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
Apr 21, 2010 | Panasonic Lands Phones
Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Dec 27, 2008 | Panasonic KX-TG5632 Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
Phone dead. no ring no dialer tone
This phone is made to work on a Panasonic phone system. Are you connecting it to a Panasonic phone system or just a normal phone line?
If you do not have a Panasonic phone system I doubt this phone will do anything (just as you describe) If you do have a Panasonic system do you have other phones that start with KX-T7??? on the system and have you tried this phone in one of the ports another phone is currently working on?
Oct 10, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
16,684 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
