DVD RECORDER NO0T WORKING
I HAVE A RECORDABLE DVD VPLAYER RELISYS RDVR250 WHEN PLUGED IN ALL IGET IS AA TICK NOISE CONTINOUS EVERY 2 SECONDS
  • 9 more comments
  • jsjimsmith2 Dec 05, 2008
    my relisys rdvr250 which is a dvd recorder is not working when plugged in it makes a single click noise at precisly every 3 seconds
    i dont think that is the ans
    even when pluged in there is no power light on nor does the remote make any differance
    when pluged in no power light comes on nor by useing remote
    if there were no power at all then what is the clicking noise
    there is no power light on or any messages on front of mc it has happend before but cannot rember howi resolved it
    also when dvd pluged in when it clicks ie every 3seconds the tv flickers
    how can it be motor when i had same prob about a year ago but cannot remember how i resolved the prob
  • 162 Answers
Press all buttons you can. unplug then re-plug several times. can't do anything on a unit that doesn't power on.
Posted on Dec 05, 2008
    Genius:
  • 3,422 Answers
HI,
Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
The only solution to this is to get it repaired.
  • 4,889 Answers
The low cliking noise usually indicates a failed recorder Hard drive. This is also known as "click of death". You can try connecting the Hard drive to a PC and run diagnostic utilities such as Check disk,Norton DIsk doctor etc., If there are too many bad blocks found then you will have to get a new HDD for your recorder.
Hope this helps,
Sai.
  • 19,396 Answers
If the unit clicks at regular interval, there is no disk inside, and unit does not come out from standby state, then it looks like the DVD started protect mode.
When an electronic device like your DVD detects an internal faults it goes in protection, that is a special diagnostic mode.
When in this state the device starts a safety switch that will prevent device from starting, to avoid further damage to the internal circuit.
Protection can be started by any internal fault, such as a bad voltage, a short, or any faulty component, like for example a blown capacitor , or a defective IC.
Things that you can try:
Unplug power cable for ten minutes.
If there is a disk inside take it out, by pressing eject many times wilst the unit is starting.
Hold down the start button (play on some model) while you plug the power back, this will reset the unit.
If the reset does not restart, that means that there is for real a fault, and it is not a matter of a jammed IC, for example because of electrostatic charges.
In that case the unit must be taken apart by a technician, tested , and repaired replacing the faulty components. This can be done only testing thoroughly the components on-board, and using a solderer to replace the defective component.
  • Ginko
    Ginko Dec 05, 2008
    I see you are refusing all solution.
    The unit is faulty and in error state, and must be takent to a repair shop.
    Call the number listed on the owner manual if you decide to call a technician.
    Read back my last comment if you want to know more about the fault.
    Goodbye
    Guru:
  • 859 Answers
You need a new motor. If you don't get the message by now, there's no point in trying.
You are better off replacing it with a $50 DVD player, and using your PC to burn with Personal Video Recorder software. You run a S Video cable to your PC from the satellite or cable box.
This is much more sensible.
  • Glenn Rogers
    Glenn Rogers Dec 05, 2008
    From VideoHelp dot com
    POOR build quality and unstable firmware make this clone of the Sampo DVE-R6
    a recorder to steer clear of.
    Problems begin from the moment you open the box. Despite being a UK model the recorder arrives fresh with a two pin US-style plug so you'll need a new three pin plug and a screwdriver handy.
    The instructions claim the recorder is compatible with DVD-R and DVD-RW discs but in my experience the unit chokes on any home burned discs. Even worse, the recorder crashes and has to be reset by switching off at the mains. In extreme cases even that fails to correct the problem and you'll have to get the pesky screwdriver out again to remove the case and extract the disc manually!
    VCD playback is straightforward.
    The on-screen graphics are poor (shades of a Sinclair ZX 81 home computer) and don't respond as you (and the instruction manual) expects. Where, for example, is the countdown when finalising a disc? (Clue: it only exists in the imagination of whoever wrote the poorly worded English instructions)
    Recordings can be edited (insert, delete and hide chapter) but not renamed. You can, at least, grab a movie's credits for the menu thumbnail.
    The remote is a poor affair - flimsy and littered with buttons it makes it too easy to press the wrong one.
    Typically for a Philips +R/RW clone, you have to press the "monitor" button before you can watch an incoming video signal - dumb.
    Only one SCART accepts a video signal the other is output only and there's no RGB support so the best you can do is use the S-VHS socket.
    A built in DD decoder and six phono outs are handy as are the component video outs (although prog scan is limited to NTSC signals only).
    The biggest problem, however, is the unit's sluggish response times and its inability to finalise DVD+R failed. The noisy unit (it sounds as though it is chewing on a bone) just spins for a minute and says everything is fine - it isn't.
    When this happens it is time for another mains switch off.
    This recorder may retail for less than £100 in the UK but in terms of build and reliability it can't even match a £39 VHS recorder.
    Sampo has a strong reputation for making fine DVD players but on this showing it needs to get its recording act together - and quick - if it isn't to lose out to fellow budget beaters Liteon.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, lets try a process of elimination:
  • power supply (unlikely), unit can still produce ticking sound presumably a relay or electromechanical device;
  • interface & electronics (a possibility), further diagnosis required; any other indicators, display, LEDs lit, blinking light;
  • electromechanical (a strong possibility) which could include servo motor, laser carriage, traverse motor, spindle motor, loading tray motor; possibly involve gearing and other mechanical component.
Recommendations:
  • if considering a DIY (do-it-yourself) then service manual is a plus or at the very least a schematic diagram;
  • access and familiarity with electronic components & circuitry, use of a DVM and a soldering iron;
  • if uncomfortable with a DIY, services of a qualified professional should be sought;
  • explore warranty options.
Should you find this posting informative and points you in the right direction, then pls ACCEPT. If however you decide to REJECT and/or request additional feedback, then possibly, further information from Benimur would no longer be viewable.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 05, 2008
    Appreciate your postback and hope that this post would still be viewable to you. Other ideas you can explore:
    • reset by switching off/unplugging at the mains;
    • should there be a disc inside, and the reset/unplug fails to correct the problem use the included screwdriver to remove the case and extract the disc manually;
    • a times it may be necessary signal press the "monitor" button before you can watch an incoming video.
  • Louie  Role
    Have you opened the unit? If yes, could you also inspect the flat ribbon cable and ensure that it is plug into the connector securely...
  • 10,594 Answers
Problem seems in power supply board in Relisys RDVR250
and most probably its hardware failure.
If this unit is under warranty, please ask supplier for warranty cover or you need tech person to examine this unit.
  • Shahid Electronics
    Shahid Electronics Dec 05, 2008
    I said power supply board has problem.
    Power supply board produce various volts for many stages in unit and if any of them get down, unit wont work and power board considers defective.
    OK, unplug unit from AC outlet for 10 minutes and plug again and check.
    Scholar:
  • 81 Answers
try to load some dvd and look the edge of the disc if there some scratch then, your disc that you use is generic and not in normal size. and also if load a cd. if there still a noise look again the edge of the cd.
and try load a new disc if there still a noise. if none, then it is ok. if there still a noise and look at the edge for scratch. if still . your should carefully look for a disc with normal size, that's all you want to secure. most do not used a generic one. make it branded.
  • Alver Clamonte
    Alver Clamonte Dec 05, 2008
    can we go back to basic if we can, unplug all the connections, except the power and then turn your player. if it is ok then.
    check the wire connection if it is in the right ports. if have some changes then after check again.
    replace your cords/connectors audio, video. if you have some spares. and then again. or repalce with new connectors audio video if you can. and try again
    but if it is not then, i'd rather refer you to a qualified service technician in your area.
  • 4,472 Answers
How long have you owned this player? How long have you had this problem? Most likely you will need to have the unit serviced by a professional. Please take a moment to accept and rate the solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Dec 05, 2008
    You did not answer any of my questions so I don't know how you are expecting further assistance. If you are asking us for the answer then how do you know it isn't the answer? Yes that definitely is your answer.
    Thanks,
    Lee
  • 734 Answers
Hi,There is a problem in the alignment of DVD Tray you need to replace the tray of your dvd player.
Thanks
  • futureloginn
    futureloginn Dec 05, 2008
    Ok, Give detail about your model??
    Genius:
  • 1,239 Answers
Hi it is better to do a hard reset...this will solve your problem.......... thank you.....
    President:
  • 2,110 Answers
Your DVD recorder motor need to be changed..so take it to nearest service center...
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Hello, when dubbing from DV mini tape to HDD
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd
Never record more than 2 hrs on a disk
there are programs for a work around that reprocess the dvd vob file with adjustments for the sync.
could also be a hardware problem
is your mini dv long play source as well?
Cheers
Dave
May 18, 2010 | JVC SR-DVM700 DVD Recorder/HDD Recorder
My panasonic remote will not work with my panasonic tv/dvd/vcr
pls clean the contact points of the battery container and check
Apr 24, 2010 | Panasonic DMRES15 DVD Recorder
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
