The chain keeps coming off the bar of my Husqvarna 353. I check for proper chain tension, tighten the bar nuts adequately. I even tried a new chain and bar with the same result. When the chain comes off, the bar hasn't moved such that the chain will simply roll back on, it must be loosened.
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
SOURCE: My Husqvarna 16 in chainsaw is no longer working.
Did the chain come off while at speed? The chain catcher causes burrs to form on the drive links when occurs. Without the catcher the spinning sharp chain contacts your leg. Were you wearing chaps? We don't need no stinking PPE!!!
Use a flat file on the drive link flats to remove the burrs.
Chain Adjustment
Lou
SOURCE: i have a 235e husqvarna with tool-less chain
Any weekday between 1300 and 1600, stop by McNasties, buy 2 premium coffees (one black). Continue on to your friendly neighborhood Husky dealer (leave the saw in the car) and present him with the coffee. Discuss the problem you are having and ask for his help. It appears to be possible to replace the tool-less setup with the tried and true version. I estimate $20-30. Probably less than repair cost for your current arrangement.
Is not new and improved wonderful? We found a way to simplify manufacture, use fewer parts, and negatively impact how well our product performs... You pay more!
This may also help Mr McKenna:
HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week.
I hope this was helpful.
Lou
SOURCE: I have a Husqvarna 345 with a 18" bar. I worked
This machine has a geared side adjust tensinor, i woud say the gear system may have striped, remove the clutch and drum, remove the allen screw securing the silver bar protector plate, the adjuster will now just lift away complete, check its function, replace if required, check the oiler is working, hold the saw over some cardboard, rev the engine and check to see if there is a good oil spray onto the card.
SOURCE: Hasqvarna 435 16"- bar nut loosens excessively
Put a lock washer on it to stop it from backing off.
