Question about Whirlpool AWM5145/2 Front Load Washer
What does the red spanner symbol mean ?
What does the red spanner symbol mean on the Whirlpool Washing Machine AW0D4505 ?
5 Suggested Answers
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 1891 Answers
SOURCE: How do I clean my whirlpool washing machine pump?
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help, it worked like a charm."
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool cabrio washing machine keeps flashing F1?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Posted on Sep 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: hi, my whirlpool aquasteam 6th
Might be wrong soap, too much soap, soap in wrong tray, heater or thermistor broken, hoses backwards, no water being sensed going into the machine, no water going out, and me fave: leak detected. More HERE
Get a free service manual HERE
Posted on Dec 11, 2010
F50 code and spanner
it sounds like it needs new brushes put on the motor or the belt is slack on the back of the machine when it is empty can you turn the drum freely by hand
Nov 18, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hi....f 13 is flashing on the machine and a red spanner symbol is on all the time, also unable to open machine even after draining it manually... thanks for any help you can offer.
You did not say what machine you have!
F 13 I have is a dispenser circuit error and the causes/procedures are
1 Unplug the washer or disconnect power
2 Check the mechanical linkage from the motor to the top of the dispenser
3 Check the wire harness to the dispenser motor and the central control unit
4 Check the dispenser motor for powered rotations
Replace faulty components
If there is a spanner symbol lit it means you need to call a repairman.
Feb 17, 2011 | Washing Machines
Manual for Whirlpool washing machine AWO-D4605
the service spanner has come on and my machine wont work it is a awod4605, it has been serviced but our engineer is on holiday so we are stuffed as we dont have the manuel to be able to disingage the service spanner help.
oh its a whirlpool
Aug 25, 2010 | Washing Machines
It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Apr 01, 2010 | Whirlpool Washing Machines
Re start problem
What is the Manufacture of the machine and the model number.
Without this information, there is no way to supply any suggestions.
Get back to me with those 2 items.
Thanks
Mac
Mar 28, 2008 | Office Equipment & Supplies
Will not spin
its prob the brushes that need replaced or your motor has a fault and needs replaced the spanner symbol means it needs a service
Jan 06, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Jan 09, 2007 | Indesit WA 125 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal De
