I am assuming you are using one of the newer version of windows, although you don't mention this. There is a free version of paperport you can download over the internet so you might like to try this. With windows you can install 32 bit versions of software onto 64 bit system and they will generally work fine. You should also try using "compatibility" mode which windows uses to help manage programs designed for older version of windows. I have some older software that wont work on anything other than windows XP so I have installed a virtual machine onto my 64 bit computer, then installed windows xp onto the virtual machine, and then installed the software I need to use. This is a bit tedious and time consuming but works perfectly and allows me to use my older software.
www.bootdisk.com try that, but if you had xp on it then get into the bios or press f.1.2 at post & switch it to "boot from cd"(make sure your xp disk is in). It should re-boot & ask to press any key to boot from cd. Continue from there. Trying to put '98 on without a floppy drive can be tricky to say the least. You'll need to find a way to load the windows dos based cd driver, from a cd just to get to the next step of the install. Avoid using 98 unless you really,really need it.
Dear,
Your HP computer may be new, but your programs must be compatible with your operating system. If your Creatacard is older, the compatibility most likely stops with Windows Vista. Windows 7 is like a "brand new day". Read the label on your CD. It will tell you which systems it will work on. I had Windows 98 and Windows Millenium. When I upgraded to Windows XP my "create" CD's no longer worked.
Try downloading Avery cards. Be blessed.
Adobe - Web Players
Broadcast and media. Education. Financial services ... (1) Not officially supported by Adobe. Shockwave Player (System Requirements) Windows98/2000/XP...www.adobe.com/shockwave/download/alternates - Cached
Starting from the start plug in the device and XP will detect and look for new drivers a search for drivers is usually done in the inf directory under windows or winnt directory If a driver is not found the computer pops up a question did a Cd or software come with this device if you install the software the a reboot is usally needed if you do not do a reboot you can try once the drivers have been installed unplug the device and plug it back in again the computer will search for the new drivers that are installed and should set up the device to work If it does not work you will need to get driver for the device that will work with XP I have a scanner than need XP drivers but will work on one of the older computers but not XP
Try running linux on it. Linux will run much better on older hardware. Depending an the specs of the system, it may not be able to handle running windows. Try ubuntu (www.ubuntu.com). If it used to run Windows XP or 98 and it wont now, try checking the hard drive. It may be corrupt. You can find hard drive check tools all across the web, google for drive fitness test by hitachi, it works great. Burn to a disk and boot to it on the older machine and do a full advanced test on the drive.
It appears that you are using Windows 98 as your operating system, if this is the case it is not compatible with the newer Ipod software. The new Ipod's require at least Windows XP service pack 2, Vista, or newest Mac software. Here is a link to Apple's website so you can check the system requirements in the support section. http://www.apple.com/support/
This particular scanner may not run to NTFS instructions. Check Windows Help in my computer- for program Compatability and try to reset the software to run as Windows 98 - it may work.
whats's the make and model of Scanner ?
