Question about RCA 24F512T 24" TV
Rca tv no picture
My rca 24" tv has no picture but sound. the tv is completely black like it's still off. i'm not getting any picture. i check the connections and they are correct. when i press the menu button i don't get anything on the screen. something is wrong with the picture tube. should i try to repair it or just invest in a new one? thanks in advance.
    Genius:
  • 1,153 Answers
You can turn up Screen control in back of set on the High Voltage Transformer and see if you see anything like a thin white line going across screen. If this is happening then it's your vertical IC output gone. It will have to be changed and a 100uf@50v cap in the same area.
Posted on Sep 13, 2007
SOURCE:
Rca tv turn on sound no picture reset get sound and picture
Sounds like software corrupted. Update the firmware. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 20, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
TV has sound but no picture.
Most likely the inverter board if the screen is completely dark (black) But if its a very darkt Blue then its the Tcon most likely. You can get either board from www.tvrepairworld.com
Mar 07, 2013 | RCA 46 46LA45RQ LCD TV
Rca scenium hd50lpw166yx12 power blinks five
I have the same problem -- now it made a loud pop and just went completely black and only the sound will turn back on,... have you received any answers to this?
May 14, 2010 | RCA HD52W66 Projection Television
PICTURE SCREEN IS BLACK
Hi
do you have a remote for your TV? or universal?
Feb 26, 2009 | RCA 24F512T 24" TV
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
TV WON'T COME ON
All the reports are showing the same problem the TV is in shutdown mode.
Something is wrong and it is refusing to start it makes a chirping or clicking sound. Solution is that it needs to be repaired nothing you can do unless you want to try replacing the motherboard yourself.
Dec 05, 2007 | RCA 24V511T 24" TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
Loose Picture (Goes completely Black)
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
May 16, 2006 | RCA MM32110 TV
RCA 24F512T 24" TV Logo
134 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
