Question about Dryers
Our kenmore dryer drum doesn't spin
It heats but doesn't rotate.
  • Anonymous Dec 07, 2008
    My belt is broken. How do I rplace?
  • Anonymous Jan 11, 2009
    we have a sears kenmore dryer model # 110.62602101, we would like to know the direction of drum spin
    Sergeant:
    Champion:
  • 291 Answers
2 to 1 your belt is off or broken / if lower panel in front will drop down you can see from there
Posted on Dec 05, 2008
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
My kenmore dryer heat very good but the drum stop working it dose not spin at all
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer Drum not rotating
check the belt,it might have slid off of pulley,make sure smooth side of belt is facing up,ridges should be touching drum
Nov 25, 2009 | Kenmore Dryers
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Dryer does not heat, drum does rotate
check the tstats on the heat can
Apr 23, 2009 | Dryers
Dryer drum not rotating
Drill holes all the way through the drum. Use carrage bolts to reattach the Bearing block through the drum into the block. Use lock washer and or locktite.
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
499 people viewed this question
Top Dryers Experts
