Question about Dishwashers
My dishwasher will not fill with water?
It will run through the cycles but will not fill with water.
  • 833 Answers
The water level sensor is not working right.  Generally, these are floats in the lower right side of the inside tub.  They jam up and will not move due to detergent buildup.  Gently move the float up and down to clear the issue.  If you have a water heat cycle, use it next time to help 'melt' the detergent buildup.
If you don't have a float, you have a sensor located in the bottom of the machine with a tube going up to the tub.  It has a thin hose and two wires coming out of it and is about 3 inches in diameter and about half an inch thick.  It has broken and will need to be replaced.  Test it by shorting the two wires and seeing if the washer fills.
Posted on Dec 04, 2008
Dishwasher cycle never completes
This is a very common complait about dishwashers taking a very long time to complete cycles. More than not if you start your dishwasher cycle wait untill your washer fills with water. Reach in and feel the temp. of the water. If it is cold the dishwasher try's to heat the water. Most of the dishwashers are not design to heat water. And here is the delay. Try to run the water at your sink first until it is hot, Star your dishwasher and see if the cycle runs correctly.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
GE dishwasher (GSD4020Y73BB)is running the wash cycle w/no water
the load limit switch under the tub!! is bad that controls the fill level! and if its stuck closed the machine will do that its under the machine on the bottom of the tub
Jan 13, 2010 | Dishwashers
Dishwasher runs through cycle but no water.
make sure water is on ,if water is on and still no water in d/w then check water control valve
Nov 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water won't fill, it run through the cycles though
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
