Question about Canon PIXMA MP460 All-In-One InkJet Printer
Printout is smeared
Black smears appear on the printout. printing is uneven. I did the deep cleaning and changed the cartridge. what next?
  • JDTec
    JDTec May 11, 2010
    Are you refilling your cartridges?
4 Suggested Answers
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
  • 54 Answers
SOURCE: Replaced the black Cartridge, however, printing is smearing
The fuser must be dirty. Change the fuser. It is also possible that the rollers along the paper path is dirty, so clean or replace the rollers.
Posted on Apr 15, 2009
  • 125 Answers
SOURCE: I replaced the toner cartridge on my printer but i
even if you replace the cartridge a hundred timesdots will not gone. Solution: take out the drum unit then examine the opc drum by turning manually there you can see a piece of gum attached, then remove it gently by using a wet cotton, then problem gone
Posted on Jan 02, 2011
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
My black ink doesn't print well despite changing cartridge and ink smears appear on the image when printing. What can I do?
have u gone through the re-alignment process and clean print heads as u should do it after every change.
May 19, 2015 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Smearing my printouts
Possible that the printhead got affected when it jammed the paper.
Take all the cartridges out and put them all back into the printer. Let it charge like it normally does.
Print a nozzle check pattern if you see any gaps or breaks or any missing lines on the pattern, clean the printhead.
May 02, 2009 | Epson Stylus NX400 InkJet Printer
Apr 03, 2009 | Konica Minolta magicolor 2400 Laser...
Smeared lines
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Jun 20, 2008 | Brother MFC 8500 All-In-One Laser Printer
Bad quality printing from the black cartridge
Select the correct Media Type setting (Windows)Print an image from another source
Change the Print Quality Settings (Windows)
try these if they dont work time for print head replacement.,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10236
Nov 30, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
