Question about Anycom - PM-400 - USB/Parallel Bluetooth Printer Adapter (856553000291) Print Server
Anycom PM-400 does not recognise HP LJ 9040n
We have just taken delivery of an HP 9040n (which is a bit of a monster, to be honest...). Transferred my anycom to the new printer from the LJ5000 we have been using for a while but the printer connectivity light does not go on, so the printer is not usable. Anyone think of any settings that I may have omitted? Cheers
    Novelist:
    Champion:
  • 202 Answers
Smade, Have you updates the firmware? this site will help you out. http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=446406&taskId=115 Good Luck, Tim
Posted on Feb 08, 2007
  • Timothy Higgins
    Timothy Higgins Feb 08, 2007
    You should do a hard reset on the print server. Find its factory reset and start with fresh settings.
    Tim
SOURCE:
Tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Feb 06, 2009 | TimeValue Software TValue 4.0 for PC
REQ:HP LaserJet 5L Repair Manual
well..those are only usually available to the HP certified field folk...
May 11, 2008 | HP LaserJet 5L Printer
Driver Installation
hi friend
u have to do this
1.plge in ur usb printer cable on usb port
2.do not on ur printer
3 put ur printer cd in ur cd rom drive
4install ur printer software
5 in between the installtion ask to u power on ur printer then u have to on ur printer
5 completing the printer installtion
try to print
& thnx uing fixya
Apr 01, 2008 | HP LaserJet 9040n Printer
HP 9040n NOT RESPONDING
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Regards
Please dont forget to rate!
Regards
Feb 28, 2008 | HP LaserJet 9040n Printer
HP LASERJET 9040n not r4esponding
ok man in system how many printer are installed if u have two printer intalled u have to set ur laser pariner as a defolt printer then after try to print in your network ur laser printer is a defolt printer so try it
Feb 26, 2008 | HP LaserJet 9040n Printer
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
Anycom - PM-400 - USB/Parallel Bluetooth Printer Adapter (856553000291) Print Server Logo
258 people viewed this question
Top Anycom Computers & Internet Experts
Alun Cox
k24674
Are you an Anycom Computer and Internet Expert? Answer questions, earn points and help others
