Question about Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor
Samsung SyncMaster 240T issues
Thanks for your time, ok I have a Samsung SyncMaster 240T, it was working great. Now when I boot up everything looks ok, but when Windows or OSX starts it beeps and keeps flashing in and out. Now I cant get it to work for a little a bit at 800 x 600. but not long. It can't handle the high res settings any more, I had that thing at 1900 x 1600 at one point. thanks
    Problem Solver:
  • 9 Answers
A) set your screen resolution to 1024 x 768 and then b)go to desktop( right click) properties -->settings--->advanced--->monitor---> change the refresh rate to 72Hz or 75Hz.
Posted on Feb 23, 2007
SOURCE:
Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
My Samsung Syncmaster 240T stopped working today. I tried turning it on, and it starter emitting a constant short beep once every 2 seconds or so, along with the green Video light blinking every time it...
Your Back light inverter power board has died. The beeping and blinking are caused by the power board repeatedly trying to start up and failing. This is a common failure point of LCD monitors2.gif after a few years of use. The heat build up in the monitor case causes parts called capacitors to blow leading to the power supply short. If you can solder you should be able to do the repair. Go to our web site at:
www.ccl-la.com/badcaps.htm We have pictures of what to look for. Now take the back off of your monitor and replace all of the caps that look like the pictures and you should be back going again. Be sure to use high temp parts, they will be marked 105c. The values you will need to get will be marked on the sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert the new ones be sure to put the polarity stripe going the same direction as the old one comes out. If you have any questions just let me know. If you don't want to do the repair yourself we do offer a repair service for $30 + return shipping2.gif.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Nov 03, 2009 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Syncmaster 932Gw stays in standby
Its possible that the cable from the laptop to the monitor is damaged. I would #1 make sure that the connection into the pc and into the monitor are both snug, if they are just slightly off it will keep the monitor from powering on. If they are snug, try another cable (if you have one) or hook the monitor to another pc (possibly your laptop, if it has a video out). Let me know if that solves the problem.
May 04, 2009 | Computers & Internet
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
The power lamp is blinking orange
Make sure it is plugged into a computer with a working video card. If error code is still there you have a main board problem. Who is the manufactorer?
Jun 30, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung 240t
u have to buy a tv tunner card its come intrnal & external just buy and connct to your monitor & enjoy tv in a monitor
Mar 06, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Display doesn't turn on, emits short beeps and blinks lights
Sounds like a low power problem, Check the power supply with a good ohm meter set to DC voltage if voltage is less than 14 v. Replace the supply. DWW
Sep 20, 2007 | Samsung SyncMaster 240 T (Silver) 24" LCD...
Samsung SyncMaster 240 T Monitors
I ordered this: http://cgi.ebay.com/14V-AC-power-adapter-for-Samsung-SyncMaster-240T-LCD_W0QQitemZ260130887919QQihZ016QQcategoryZ86707QQrdZ1QQssPageNameZWD1VQQcmdZViewItem on eBay when my power adapter died, and it worked like a charm.
Oct 06, 2006 | Samsung SyncMaster 240 T (Silver) 24" LCD...
Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor Logo
259 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
