Question about Dryers
Rivet gun needs put back together. rivet was stuck in gun and was broken down to remove rivet. gun was left without the spring being put back in. top hole on gun is stretched and bent backwards. is it worth saving?
michigan man
  • 3533 Answers
SOURCE: How to take the front grill Out
you can try your local dealer and they can give you a diagram at the parts department
Posted on Mar 20, 2009
  • 631 Answers
SOURCE: My dryer is making a loud clunking sound with each
It could be that your rollers are wore out and let the drum fall down. If you stick your hands inside of the drum can you lift it up with your hands like maybe the drum is down lower then it should be? And do this while not running of course. lol See if there is any slop in the drum with your hand lifting up and down on the drum. See if you can also pull it forward any.
Posted on Jul 29, 2009
  • 8457 Answers
SOURCE: LG Projection TV Model# RT-49NA11T Green
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Jan 10, 2011
  • 403 Answers
SOURCE: Sir, i was given a
seeing that you have a staple gun that costs about $20 new, it would most likely cost more then that to have a single part mailed to you. Buy a new gun
Posted on Mar 24, 2011
  • 19396 Answers
SOURCE: Step by step instructions for
Here you go:
1 - Remove one screw at each side's fender:
2 Remove two screws and clips at the back.
3 Pull out the bumper.
4 If needed remove screws holding spoiler support
5 Perform operations in reverse order to reassemble
Posted on Apr 16, 2011
How to replace a quarter window on 95' Ford thunderbird LX. Passenger side quarter window and what tools will I be using.
Remove the door panel, remove the window trim, remove the window regulator, Remove the window frame(push down ,then pull out from the top), Remove the broken glass from the seal, install window. Put back together in reverse order. You will need a Phillips screw driver, a drill and 1/4 bit, a 10 MM wrench or socket, 1/4 rivets X 1/2 inch long and rivet gun that handles up to 1/4 inch rivets.
May 03, 2015 | 1995 Ford Thunderbird
How hard is it to replacing motor for power windows
Replacing the motor itself isn't too difficult. you simply drill out the rivets that hold the old motor in place and remove the motor. Putting it back in is more difficult as you'll need small nuts and bolts that will allow the window to move without catching on them. I tried to find rivets and a rivet gun that were big enough, but never did, so I had to resort to the nut and bolt method to hold the motor back on the bracket. Be careful when you try it out the first time, the nut or bolt may stick out too much and you can break the window when rolling it down.
Jun 23, 2014 | 2000 GMC Jimmy
How to fix a grabber reacher?
I have a idea to help you .If apart ,you mean the rivets are missing? If this is the issue, find or ask a family member w/ a pop rivet gun.The claws that do the grabbing are stamped,labeled (L)-(R). Reassembling the Grabber w/ the rivet gun wouldn't be too difficult .I could fix your problem, if we were neighbors!
Mar 03, 2013 | Unger NN140 Nifty Nabber Trash Grabber 51"...
I have a toro personal pace gts self propelled. only model number i foind was 2h802. pull cord broke, would like to know how to replace it
You can buy the whole part...cord,handle,recoil spring all in one piece and remove the old install the new...or you can just buy a legth of pull cord and swap everything over.
First take off the top 4 phillip screws and remove the plastic cover....don't forget to pull off the oil fill cap, next drill out the center of the three pop rivets that hold the recoil spring in place, use a drill bit a little smaller than the rivet, next tap the rivet out using a punch and a hammer, next install the pull chord by first rewindind the coil spring then locking it oin place so it wont twist back and install the new line(pull cord) install it on the top of the motor and install 3 new 1/4" aluminumn pop rivets 3/8" long with a pop rivet gun all can be purchased atb Ace Hardware...reinstall the reverse of dismantle proceedure and happy mowing...don't forget to attach the black plastic/rubber pull cord handle.
Happy Mowing!!
Jul 22, 2010 | Toro Garden
I need to put the top vent back together electric fry pan
Fix #1
These are usually riveted on. If you can find a small enough aluminum pop rivet (most lids are aluminum), you could pin it back together with that. The tricky part is ensuring that the rivet allows the vent to rotate between the opened and closed positions. I suggest cutting out two pieces of non-corrugated cardboard from a cereal box and punching out a hole in each the same diameter as the rivet. Use one on each side of the lid for a washer for the rivet. Include an aluminum washer for the tail end of the rivet. Your parts stack from the inside of the lid should be rivet (head end), cardboard washer, vent piece, lid, cardboard washer, metal washer. The pop rivet will be compressed against the metal washer on the outside when you operate the riveting tool. I suggest having the head on the inside of the lid because it will be easier to clean.
After you compress the rivet, tear the cardboard washers out. The vent should now pivot correctly.
Fix # 2
Use a 2-56 x 1/4 stainless steel screw (or similar metric size) and two stainless steel nuts. Assemble the vent to the lid using the screw and one of the nuts. Tighten the nut only until it starts to drag on the vent, then back it off slightly. Next, put the other nut on. Hold the first nut in place and tighten the second nut down onto it to lock it in place on the screw. The vent should still turn freely, but the nuts won't come off without tools if you did it properly.
Do not use plated or plain steel hardware. These will contaminate your food.
Oct 30, 2009 | Presto 06821 Electric Skillet
How to replace exterior door handle on the back passenger side. What tool is needed?
there are two rivets that you will have to drill out. on the inside of the door, there is a threaded clip that holds the linkage in, you will have to open it (it opens like a door, it may be a little stubborn, but it will open). then put your new handle on, and then the linkage back in, and snap the clip back in place. you will need one of the bigger pop rivet guns because the rivets are 1/4 ones. also, when you go to rivet the handle back on, tape some cardboard under the handle. that way if the rivet gun drops after it snaps off the rivet, it will not scratch the door. hope this helps you.
Oct 14, 2009 | 2000 Ford Explorer
Plastic Guide rail on sunroof broke
I just purchased a used yukon xl. Both plastic rails are broken.
Solution: Drill out the blind rivet. Start with 1/8 drill bit and remove the head off. The plastic broken part can now be removed.
Install a blind rivet through the new plastic rail and use the rivet gun to squeeze the rivet in place. Make sure it is the right length.
get a grip gage and determine the right rivet for it.
very easy job.
Jul 01, 2009 | 2003 GMC Yukon XL
How to replace auto lock/unlock actuator on 5th door of 99 Chevy Tahoe. panels are off, looks riveted on.
some are bolted, but most are riveted,you need to drill them out and replace them with special rivets,5/16x7/16 all gm bodyshops have them 75cents to $1 each, but you need specail heavy duty rivet gun ,you will pay between $65-$100 for the rivet gun, if you have a friend at a local bodyshop i would borrow it with a deposit ,they get there gun back you get you cash back,hope this was helpfull
Jun 28, 2009 | 1997 Chevrolet Tahoe
Broken recoil on 10 briggs the recoil rivets came out of housing
I have had the same problem and use a pop rivet gun with steel rivets when reassembling the housings. Frequently these rivets get loose, & need drilled out & changed. I am assuming that the rivet holes in the housing are not elongated or you might have to drill to the next larger size rivet to install them. Hope this helps you, Rick
Apr 11, 2009 | Briggs Electrical Supplies
Broken plastic rivets
you can try flat bolts or get a rivet setup and just use metal rivets
or google plastic rivet gun and you can find all kinds of stuff to buy but thats never any good
Mar 09, 2009 | Ultra Products Grid (ULT33137) ATX...
Dryers Logo
774 people viewed this question
Top Dryers Experts
