Question about Zanussi FLA1001W Front Load Washer
Won't heat water anymore - only washes in cold water
The washing machine doesn't seem to heat the water anymore, it will only wash with cold water
    Novelist:
    Champion:
  • 244 Answers
U need to take the back half panel off once off u will see the two thermostats and the heater element you can test the element by undoing the wires and getting an old wire with plug on 1 end and bear wires on the other place corrisponding wires to were that wire had come of turn plug on and if it is working it will heat up straight away which means the thermostats need replacing if it doesnt then the element needs replacing
Posted on Sep 09, 2007
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
Does the hotpoint model 9534 have a heating element in it to heat up the water if the temperature of the incoming hot water is not high enough for the set wash? Because when it only has cold water going...
yes it has an element. first thing is to make sure you dont have the "econmy" button selected as if you do this causes the machine to skip the heating stage.
if not its an element you need part number 1601318.
remove the front facia and panel and you will find the element in the front of the drum
Jul 11, 2011 | Washing Machines
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold water valve not working
Sounds like either the water valve is bad, or the screen in the valve is clogged. Take the hose (cold) off at the valve and look for the screen to be clogged. If it is not clogged, replace the water inlet valve.
Jan 20, 2010 | Washing Machines
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Not able to do hot washing
My LG Toploader (wft753a) has a cold and a hot inlet, and the mechanism inside the machine simply turns the flow from each tap on and off. There is no internal heating element in it.
Nov 22, 2007 | LG WFT1071TP Top Load Washer
Zanussi FLA1001W Front Load Washer Logo
238 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
