Question about Garmin GPS
When I attach my garmin nuvi 760 to the car mount and plug it in the car charger it will not power off and on when the car turns off and on. For example if I turn the car off the garmin continues to charge being fully powered. When I turn the car on if the garmin is off it will not turn on without manually doing so.
  • Garmin Master
  • 2,130 Answers
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Posted on Dec 04, 2008
My car charger will not charge battery in garmin Nuvi 760
The fuse may be gone in the charger. There's a ring, near the silver tip, of the plug that goes into the cigarette lighter. If you unscrew the ring the plug will come apart. Take care not to lose the silver tip as it may fall out. Replace the fuse and it may solve the problem.
Feb 28, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin won't come on
plug it in to the wall charger or car charger for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Sep 05, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I have a Garmin 760 did not come with a ac
The AC charger plugs into the mini-USB port on the bottom of the unit. The term AC is somewhat misleading as the AC charger plugs into an AC outlet but provides +5VDC to charge the units internal 3.7VDC battery.
You can purchase an OEM AC charger here:
http://www.sharc.net/gps_repair_prices.htm
- Jim
Aug 23, 2009 | Garmin Nuvi 760 Car GPS Receiver
Where do i plug in my 120v charger on my garmin nuvi 760 gps
Hi I have this model too. You must have the 120v charger with the Mini-B  port on it. It plugs into that port on the bottom(PS3 controllers cameras, and other Computer devices often have a mini-B USB
Apr 04, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
I'm not sure where I should plug the recharger.
The charger plugs into the mount. You should be able to download the manual in English from the Garmin website.
Dec 15, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
New Nuvi 760 that won't work
Using the PC to charge a Nuvi is not the correct way to charge. Use either the AC wall charger or DC car charger. Many PC USB ports can not supply enough current to charge a Nuvi.
- Jim
Dec 12, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Assembling nuvi 760
Attach the window mount to your GPS unit ...it clips into the bottom. Insert the power supply into the mount on the right side. Of course plug it in to your power supply in your vehicle that is hot or turn on your cars power supply
Dec 08, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
GPS Logo
145 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
