Question about Dewalt DC011 AM/FM Radio
The tuner and buttons don't work.
When I turn on the radio you can hear something very faint, and neither the tuner or the clock and radio buttons work
  • MAUER_62 Feb 09, 2009
    NOTICED THIS MORNING WHEN I GOT TO WORK I TRIED TO TUN ON MY RADIO AND THERE WAS NO DISPLAY AND NONE OF THE BUTTONS WILL WORK. WHEN I TRY TO TURN IT ON I HEAR THE RELAY CLICKING BUT NOTHING WILL WORK. I INSPECTED THE BOTH FUSES AND THEY ARE GOOD. IT WILL CHARGE THE CORDLESS BATTERY.
  • Anonymous Mar 11, 2009
    i replaced the 2 aa batts and it worked fine.im glad i didnt throw the radio out.thank god for thr internet.
REPLACING THE BATTIERIES WAS THE FIRST THING I TRIED
Posted on Feb 17, 2009
Take out the 2 AA batteries worked for me
Posted on Dec 13, 2008
How do I set my clock on my accurian table top hd radio?
1. Turn on the radio
2. Hold down the "Clock" button. It will switch to clock-date setting mode.
3. Use the "Tun-" and "Tun+" buttons to adjust each field.
4. When one field is set, push the "Clock" button to get to the next one, and when all are set push it again to exit.
Aug 21, 2011 | Radio Shack "Accurian" Tabletop HD Radio...
Radio worked fine......then I was trying to find another channel by turning the tuner knob and all of a sudden it just locked and when I turn the tuner knob it won't change stations. Nothing works but the...
This may help: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Feb 08, 2011 | Dewalt DC011 AM/FM Radio
Power to radio but can not turn on radio
plzzz remove the resistence 10 k and put the hardware on roof and hit it and go
May 27, 2009 | Harley Davidson 426290 AM/FM Radio
radio microprocessor may have "locked up" after installing power back to radio. Unit will need to be cleared. Contact Iron Cross Audio (www.ironcrossaudio.com) for advice on how to proceed
May 02, 2009 | Harley Davidson 426290 AM/FM Radio
How do i shut off the alarm mechanism on the mini 300 world band reciever
Here's a link to the eton site where you can download and print the manual for your radio. Instructions for the alarm function are on page 7:
http://www.etoncorp.com/upload/contents/307/Mini300_Manual_0107.pdf
Bill B.
San Antonio
Apr 10, 2009 | Grundig Mini 300 AM/FM/SW Radio
Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Nov 20, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Display / Clock display not working
SONY MHC-EX50
Het is al een paar weken verder, maar ik ben eruit: C161 en C162 (100uF/35V) in de voeding zijn slecht.
wel 105 graden elco's gebruiken en hoger dan 35 volt, liefst 100v
et gaat dus om een VFD (Vacuum Fluorescent Display) die geen gloeispanning krijgt. Het vervangen van C161 en C162 lost het probleem helemaal op.
Radio: ST-EX100
Amp: TA-EX50
Symptome=Tuner-Display zeigt nichts an, sonst Tuner OK.
Defekt=C161 und C162 (100µF,35 V) auf der Tunerplatine ersetzen.
Wenn bei dem Sony-Tuner RDS EON ST-EX100 (z.B. zu der Anlage Sony MHC-EX5, aber auch MHC-EX 70) pünktlich eine Woche nach Ende der Garantiezeit die Beleuchtung im Display wegfällt und man deshalb leider keine Sender mehr programmieren kann, dann handelt es sich vermutlich um eine fiese Soll-Bruchstelle.
Auf der Platine des Tuners sind zwei Kondensatoren zu schwach ausgelegt und gehen zwangsweise früher oder später kaputt. Die Reparatur ist ganz einfach. Man kauft zwei neue Kondensatoren (100µF,35 V) - kosten nur ein paar Cent! - und besorgt sich einen Lötkolben. Dann schraubt man den Tuner auf, entfernt auf der Platine die Kondensatoren C161 und C162 (die sind namentlich gekennzeichnet) und ersetzt sie durch die neuen.
Nov 12, 2008 | Sony ICF-2010 AM/FM/SW Radio
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Sharper image clock radio for shower
To set tuner presets:
1. Manually tune desired frequency.
2. Press MEMO button, Display will flash.
3. Manually enter memory position, 1-5.
4. Press MEMO button again.
The manual is available as a PDF file from the Grundig web site. Or, if you will e-mail me at deepblack <at>ugaalum<dot>uga<dot>edu and put "Yachtboy" in the subject, I will e-mail it to you
Mar 23, 2008 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Dewalt DC011 AM/FM Radio Logo
461 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rani wadia
Rani wadia
masterwest
Level 1 Expert
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
