Question about Microsoft Xbox 360 Console
Power Issues Hi, When I turned on my xbox 360 the green light comes ono for a sexond then turns back off. Everything is plugged ini and connected properly. I don't knkow what the problem is. Can anyone help?
    Problem Solver:
  • 16 Answers
Your power brick is messed up
Posted on Jul 09, 2009
Xbox 360 elite wont turn on no lights power cord lights up
Hmm... it seems it's a problem with the power adaptor. Have you tried to replace it?
Mar 23, 2013 | Microsoft Xbox 360 Elite Console
My xbox 360 slim turn on but instantly turns back off
Sounds like the old brick cooked the Xbox somewhere when it allowed it to overheat. You'll need a replacement console or you could try baking the board but I don't recommend it if you haven't before.
Jan 26, 2013 | Microsoft Xbox 360 Slim Black Console
My xbox 360 will turn on but the lil green circle wont light up and controller wont connect?
Your xbox 360 may not actually be on if there's no green light and your controller won't connect. If pressing the power button doesn't turn on the console/green light doesn't come on then your motherboard may be bad.
Jan 14, 2013 | Microsoft Xbox 360 Console
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
With everything connected the xbox 360 console isnt turning on at all
There may be a problem with your power cable. Check the light that is on the brick of the cable, if it is green, then the problem is in the console, but if it is yellow there is a problem with the power supply. Make sure the power supply is plugged in properly to the wall socket and the console. If the light still stays yellow, unplug the cord and then plug it back in. If the light is still yellow, you will need to call (1-800-4MYXBOX) and get it repaired.
Dec 28, 2010 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
When i turn my xbox 360 elite the button on the console blinks in the color red and it wont come on the screen and sometimes it turns on but it just turns all green or it freezes
Ok Clarify ..Lay the 360 down on it's belly(Horizontal) there are four lights around the power button..Those lights are meant to tell the manufacturer for certain issues of the system i'll give you a link to these colors and you email me back with what you see .. http://xbox-experts.com/errorcodes.php
Jun 10, 2010 | Microsoft Xbox 360 Elite Console
I plug in the adapter and no green light comes on. connection is fine
i plug up everything rite on the xbox and have no power no green light visible on adapter does it mean my adapters broke!
Jan 21, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 won't turn on
To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Sep 01, 2009 | Microsoft Xbox 360 Console
LED light not coming on when connected to console
I'd check to see what the manual says about it.
There are several sites that offer help on issues like these
xbox scene and llama.com just to name a couple.
Nov 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
