Router what are the role of router in wan technology?
    Problem Solver:
  • 10 Answers
It directs traffic.
Posted on Dec 04, 2008
Wlan light blinking
It may be the router is not getting wan connection from the modem. Depending on the technology the ISP is using, it could be that they need to allow to assign an IP to your router or there are confliction of configuration or cable connection type between your router and the modem. Or the service to your modem is interrupted for some reason. Try to skip your router and see whether your computer works by connecting it to the modem directly. If that works, reset the router and reconnect it to the modem and see.
May 26, 2016 | Computers & Internet
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
Cisco 861 behind Wimax Router from ISP
> WAN IP: 44.55.66.777
> ISP Router LAN IP: 111.222.333.174
> Cisco Router WAN IP: 111.222.333.175
Really? Each "octet" must be a value between 0 and 255, inclusive. A value such as '777' is not valid
Aug 27, 2012 | Cisco 861 Router
WAN ADDRESS OF MY ROUTER IS 192.1681.1 BUT I CANNOT PING TO MY ROUTER FROM TRUSTED NETWORK
Your WAN address should be 192.168.1.1
I hope this will help you.
Thanks for using FixYa.
May 15, 2011 | WatchGuard Technologies FireBox SOHO 6...
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
I have problem? how can we connect router in
- Check physical connection (Connect the modem to the WAN or Internet then hook one of the computer to the LAN connection.
- Open a browser then access the configuration page of the router.
- Under on tools create user ID and password.
Another is:
- Open the wireless settings under setup.
- Change the wireless network name/ SSID and set the encryption or security to WEP or WPA.
- Check the wireless network connection if you can log in with the wireless network name/ SSID with the password.
^_^
Feb 18, 2009 | Blitzz Technology (BWA611) Router
Trying to connect buffalo router to comcast modem for wireless internet
You will need to use the MAC address of your PC. Do an IPConfig/all while connected with a ethernet cable. That's whatg you need to put in under Wan--> WAN MAC address
Jan 17, 2009 | Buffalo Technology AirStation G54...
What is the role of router in wan technology?
Hope u must be aware of network packets. Each network have its unique network address through which the computer within the network communicate. If a computer with different network address want to communicate with such an environment the packet need to be routed within the 02 different network, which is done through a device called router.
Router is a network device which route's packet between different networks..
An electronic device that connects a local area network (LAN) to a wide area network (WAN) and handles the task of routing messages between the two networks.
For Other Information click here
Dec 04, 2008 | Computers & Internet
Router
i asssume that you have connected the ethernet port of the modem to the wan port of the router. if that would be the case, yes you need to connect the computer to the lan port of the router to get internet access. that it if you want your computer to be directly connected to the router. but if you're planning to connect wirelessly, you just need to make sure that your router and computer have a wireless capability and your computer.
Jul 04, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
