Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool top load washing machine dances too much on spin cycle
What may cause this
  • flavia1971 Feb 07, 2009
    I have the same problem with WTW5200VQ (model)
  • Anonymous Mar 07, 2009
    washing machine is only 3 months old and moves too much on spin cycle. Two people from brandsmart came out to try to fix it and they could not. a third person will be out next Saturday
    Sergeant:
  • 399 Answers
 Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Dec 06, 2008
My whirlpool wtw4950xw2 top loader washing machine sounds like a jet taking off during spin cycle ... How can I fix it ?
You can unbalance the load more to get a quieter spin, but otherwise you may have a worn out gear system that produces more noise than the spinning tub itself. Check with service to determine the exact cause of the noise.
Feb 01, 2015 | Whirlpool WTW4950XW Top Load Washers
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool 6AWM8143 Front Load not starting spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
Do you know the button sequence on a WHIRLPOOL CALYPSO which would check the washing, rinsing, spinning and draining cycles quickly? Saw a repair tech do it once.
if you remove the "emblem" from the front of the machine(very front edge of maintop assy.justs prys rigth off) behind it you will find a screw 1/4 inch socket. after removing hte screw the main top will pull foward slightly andthen lift backwards, under there glued to the inside front panle youll find a tech manual with all hte info on all testing procedures,uncliding hte "key dance" to get into different modes"
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Agitator/nunater not working.... HELP!
you have a bad u-joint assy,comes as a kit with the leveler..they used to put instructions on replacement in the kit.i assume they still do but i haven't done one in a while.good luck
Sep 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Dancing washing machine
if its real new as in you just installed it look behind hte unit for shipping braces that haven been removed.. they keep the machine solid in shipping and reek havok if not uninstalled
Mar 17, 2008 | Whirlpool AWM6100 Front Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
272 people viewed this question
Dan Webster
Dan Webster
Sal De
