Question about Baby Trend Flex-Loc Infant Car Seat - Silverado
Installing the carseat base without anchor locks
I just need to know how to install the base in a car without anchor locks available
4 Suggested Answers
  • 25 Answers
SOURCE: how to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at consumer@djgusa.com or call them at 1-800-544-1108.
Posted on Feb 18, 2009
trials78
  • 28 Answers
SOURCE: cant get it to be tight in the car install. Tried
With car seats, you literally have to put your weight on top and get the belt as tight as possible because of the seat cushion. If you put enough weight on it, shoulder or belt strap will both work with this method.
Posted on Nov 07, 2009
  • 45 Answers
SOURCE: question about the base to a car seat
What make and model is your seat? Look in the instruction booklet to see if you can use it without the base - you probably can, but the instructions are the final authority. If you don't have it, check the manufacturer's website for a download, or a 1-800 number to call to request it - you really should have it for reference.
For infant seats, extra bases are usually available: people with two cars like to put a base in each car so they don't have to keep re-installing it. Again, check the manufacturer's website.
Posted on Mar 25, 2010
Need to know where anchor points are in 1989 Mitsubishi Starwagon or do I need install them
Hi
In a 1989 model vehicle it is unlikely that there will be integral anchor points such as IsoFix. You should contact Mitsubishi to discuss with them whether there are anchor points available in this vehicle or whether they can be retro fitted. Please note in order to meet standard for installing an IsoFix or similar fitted carseat the anchor points must be installed by the vehicle manufacturer.
Jul 14, 2013 | Baby Gear
Quinney 01483cstb
Hi Melanie - Without knowing which model carseat you have we're unable to provide installation directions. Please visit your local retailer for assistance or visit www.maxi-cosi.com then select your country, and the make and model carseat you have for instructions.
Nov 29, 2011 | Quinny Baby Gear
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Are there Anchors to install a carseat in my 95 mazda protege? Where are they?
mcdevito75 here, As far as I know regarding Baby seats for autos these so called anchors are built into the baby seat itself, refer to the owners manual for the baby seat to install.
Apr 11, 2010 | 1995 Mazda Protege
Question about the base to a car seat
Mar 24, 2010 | Baby Gear
Installation of base into car
Place the base into the car ,pull seatbelt through the large holes on the base, lock seatbelt and place the infant carseat in you should hear the seat click into the lock position. Hope this helps.
Jul 08, 2009 | Evenflo Journey Elite - Pink Lemonade...
How to install infant car seat
Jan 27, 2009 | Eddie Bauer 22-625-BLD
Safe Seat stuck to base
Ok. You should be able to put your weight on the base to create some slack in the strap. Then push the release buckle and alternate your weight to pull the strap and loosen. Then you'll have enough room to manipulate the improperly installed latch.
Aug 25, 2008 | Baby Gear
Baby Trend Flex-Loc Infant Car Seat - Silverado Logo
271 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
