Question about Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer model LTF530DS loose drum
I have a frigidaire front load wahser and the drum seems to be loose. I first noticed dsomething wrong when the washer started making a load thumping noise like it was off balance at the end of the cycle. When i further examined it I've noticed that the drum is wuite loose almost as if it isn't secure anymore it rocks when I'm putting clothes in it and now thumps everytime it spins
  • Anonymous Mar 16, 2014
    Drum can be pushed creating a finger-width gap between drum and door-seal. Machine doesn't leak. Loud banging during spin. Black marks on clothes.
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
Posted on Aug 07, 2008
I think that I have a broken spider as well. Problem is I cannot get to it. I cannot get the large drum pulley in the back off of the square shaft. Any secrets or just keep pulling? Thanks.
Posted on May 04, 2010
    Sergeant:
  • 272 Answers
It sounds like your spider is broken it is on the back of the drum that's in side the machine and if that's gone normally your barrings need to be replaced i would normal do the barrings for abaut 65 pound if you do need a spider you are looking abaut 30 pound so if you go down to your local second hand shop they might take the job on it ain't a walk in the park but it can be done i have done so many now im in ipswich if your near me i would do the job but it would seem every one is so far away but try your local second hand shop they should help you.
Posted on Jan 05, 2008
You might check the shocks that help to stabilize the drum during operaton. Mine started doing what you are talking about, right before it broke. I looked like I was on a mechnaical bull, trying to get it shut down.
Posted on Aug 18, 2007
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
Tub is loose
Hello Rob - Try rotating the drum manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidare affinity front load washer the drum seems very loose is this normal?
yes as it it is spring loaded ,thier is only one bearing at the back but the support mounts are all spring loaded ,you could get someone to take the top off and make sure that the springs are all connected and one of the support brackets on the drum isnt broke off
Dec 06, 2011 | Frigidaire Affinity ATF7000E Front Load...
Our washer will spin in the wash cycle, but not in spin cycle??
Check the door switch -- it it's loose or otherwise faulty, the washer will not spin. The door switch prevents the washer from spinning when the door is open -- if the swithch is malfuntioning, the wahser thinks the door is open. Door switch is on the circumference of the door opening.
Charlie
Jan 14, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum in Frigidaire GLTF1240AS0 has loud clunking noise
The rear drum support must be replaced.The supporting ball has eaten into the support cup.The belt will have stretched and must be replaced also. You can do the job yourself.
Aug 18, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire Front Load Washer LTF530DS
if your door wont lock then its your door switch it had its day if you go down to your second hand shop they should help you it should cost about 15 pounds its a easy job and don't take any time to put in make sure you wright down the model number of the machine hope that helped you
Nov 12, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
1,018 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
