Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Unit acts as if theres no air flow
My unit was working the light for cleaning the unit came on and I continued to run the unit. It finally stop working I cleaned the unit now it acts as if theres on air flow and the ready is on.
  • 734 Answers
All Sharper Image Ionic Breeze Ionizer have been recalled and are no longer supported.
See the Chapter 11 link
http://www.aircleaners.com/sharperimage2.phtml
See the EPA link as well
http://www.epa.gov/iaq/pubs/ozonegen.html
Posted on Dec 04, 2008
The pre-filter light is on when I turn it on
First, Turn off the unit. Thern, Rermove the pre-filter & gently clean with soap & water, rinse well. Finally, dry & replace back into unit. Then turn back on unit & the light should be off.
Nov 04, 2013 | Honeywell 52500 HEPA AIR CLEANER
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
My Ionic Pro Turbo air purifier is blowing air in intervals of 30 seconds, blows for 30 seconds then stops for 10 sec. then repeats. Is this normal or do I have a defective unit? Thanks, Jerry
Have you cleaned the unit good and made sure that there is nothing crossing the grid wires? It sounds as if it is cutting off and resetting for some reason. Mine runs continuously. I take an air compressor and blow mine out every time I clean it. Also, on some models, you have to hold the on button down for several seconds to reset it after cleaning. Hope this helps.
Jul 03, 2009 | Ionic Pro FULL-SIZE Air Purifier
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Fans not working
Yeah, I had this happen to one of mine, the motor bearing siezed. Even though mine had run out of warranty and I kludged a fix for it Oreck replaced it anyways after inspecting the unit.
Temporary kludges that worked: light machine oil on the motor bearing, flipping the motor over internally, turning the unit on its edge so that it rides on a 'fresh' part of the bearing, running the unit on 'high' while I was out of the house.
Apr 27, 2008 | Oreck XL Professional Air Purifier
Ionic Breeze Professional Series Table Top Model
you need to clean the unit entirely, but be prepared, it will eventually do it again and again until it finally stops working all together. I have sent three back in one year and now they won't do anything since itis longer than the 1 year warranty. No wonder theyare bacnkrupt; selling worthless ****!!
Mar 09, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sizzle
I had the same problem and found that the mylar on the tabs at the bottom of the plate assembly was damaged (torn). I was able to repair the part myself using mylar tape. This solved the sizzle problem. I
Nov 22, 2007 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
