Question about Toshiba 32A60 32" TV
Remote control SENSOR not working
Remote control functions on other Toshiba sets. The TV works well, but only the on-set buttons will control it. Nothing is obstructing the sensor and it lights up when the set is manually turned on.
  • sazfone Jan 28, 2009
    I have a similar problem. My remote works intermittently  with my Toshiba tv. It works fine with other tvs and our dvd.
Can someone post a response to this problem that actually answers the question? I have the exact! same problem, and as w2ith the original poster, the REMOTE is fine. The original poster's remote works fine on other toshiba TV's, and I can get my mom's remote (the toshiba TV is hers) remote to work with the Sony VCR in my room. Even though i can't get the toshiba remote to work with the panasonic VCR that's hooked up to my mom's toshiba (it must be using a code that's not listed in the toshiba TV's manual), the remote DOES work on MY VCR. So I'm guessing our problem is with the receiver in the TV itself. Is that hard to replace? could we do it yourselves? Or do we have to take it into a shop?
Posted on Aug 24, 2009
    Sergeant:
    Champion:
  • 272 Answers
This could be a fault with your remote control. It will need checking by a Television Technician.
You can clean the remote control yourself if you are careful. You will need a spray can of Servisol IPA 170.
  • Carefully split the remote control unit along the seal between the top and bottom of the unit.
  • Carefully notice how you then dismantle the inner components. (I lay the components out in the order I take them out of the unit).
  • In a logical order spray, clean and dry each part.
  • When you have cleaned all the components, reassemble in their reverse order of the way you dismantled the unit.
  • Fit new batteries and test the remote control.
If this fails to solve the problem, you will have to take the remote control to a Television Technician for testing.
If the remote is found to be beyond repair, visit www.semenedis.com who may be able to supply you with a replacement remote control. I trust this information will be of help to you.
Posted on Dec 04, 2008
Tv button wont work
Check whether the panel lock function is ON. If it is ON, make it OFF. Refer the user manual to your TV for more details.
Jul 04, 2016 | Toshiba CT-90255 Remote Control
Toshiba tv 32a43 changes input by itself
I will try to explain this: I first presume there is a physical button on the set for the input options.
I have seen this a lot:
Not the plastic button on the set but the tiny push switch behind it.
These are called momentary switches as only should function when the plastic button is pressed and contacts the momentary switch.
They go bad, and will internally engage without be touched.
The simple way to prove/disprove this is to open the set and get at that switch which usually is soldered into a small circuit board--two pins for the switch and maybe two more tabs for mounting.
If individual switches unsolder and REMOVE THE INPUT SWITCH (the one under the plastic button on the set)
Set should now operate normally and remote should have same feature on it. If it works you do not have to replace anything.
FYI: the reason the remote may not be working is the buttons on the set have PRIORITY over the remote.
Both the remote and the buttons go to the same area inside the set but buttons are #1 in line.
Dec 05, 2012 | Toshiba 32A43 32" TV
My toshiba t.v...model#mw20fm3 doesnot work on the remote . i think the electric eye is not functioning. how can i get this repaired with a minimum cost, and close to where I live (San carlos, san...
There is a quick test you can do to figure out if the IR transmitter on the remote is broken or if the TV's IR sensor is at fault. Using a digital camera (cell phone works too) set up a picture of your remote's IR transmitter. DO NOT TAKE A PICTURE. Simply look at the sensor through the camera's screen. Now while looking at the screen press a few buttons on the remote. If you (through the camera's screen) see a red light coming from the remote, then the remote is fine. As far as getting it repaired, you can look for a TV repair shop in your local yellow pages. Call a few and ask for a quote.
Jul 18, 2011 | Toshiba CT-90157 Remote Control
TOSHIBA SER0324 Remote Control. I just got a Toshiba TV with this remote and I am unsure how to set it up.
Hello
You can prgramme with
toshiba remote control with Toshiba TV, eventhough you haven't its manual or codes. Proceedings are :
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 12, 2011 | Toshiba Televison & Video
Remote control brocken and dont know how to turn on tv without it
hi,
just press the power button or channel up button or down button on the pannel of your tv.
ok
Mar 07, 2011 | Toshiba 37C3030D 37 in. LCD Television
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Televison & Video
Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
Aug 01, 2009 | Toshiba CF32H50 TV
Our daughter gave us a Toshiba TV and remote. We plug in the TV and hook up the cable,and try to turn on the TV but nothing happens. We can turn on the TV with the TV button,and it works fine,but we would...
If the remote is the original Toshiba remote, it obviously should work the TV. Have you checked to make sure it has good batteries? Also, if old batteries leaked in it at any time there may be corrosion on the battery contacts keeping it from working. Make sure the metal contacts look shiny, not crusty and corroded.
If the remote still doesn't work there are two possibilities. One is that the remote is just bad. You can get a universal remote, set it for Toshiba and try it. It will at least control power, channel and volume functions. If the universal remote doesn't work, the remote sensor in the TV would be the probable cause. Like any other part, they can sometimes fail.
Apr 11, 2009 | Toshiba Televison & Video
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Toshiba 32A60 32" TV Logo
313 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
