Have to replace ignitor on coleman furnace every year
Furnace runs fine then stops; diagnostic lite blinks once to indicate ignition failure; ignitor shows black burn marks; replace ignitor and unit will work for the cold season then burn out next year; has done this for six seasons; it is a coleman for manufactured hones 70.000 btu. I put voltage meter on it and it read 122 volts; is this too high and could this be burning out ignitor?
  • yakima_canut Dec 04, 2008
    Thanks for your suggestion; I will give it a try.
  • Anonymous Dec 06, 2008
    We have the same furnace, this is the 8th. winter and every year we have had to replace the ignitor also. The control board twice and we are totally sick of this furnace. Will never recommend a coleman to anyone. Our repairman sells Lennox and Coleman and he even said they are not very reliable furnaces.
  • 1,420 Answers
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Posted on Dec 04, 2008
What would you do? I have a coleman gas furnace DGAA007BDTB, I get the LED diagnostic code 1 blink, so I check the conections on the circut board, it is hot in some places...could that be the reason I
Can you give a sequence of events description as to what it does? A 1 blink code just means ignition failure, but without any more details, I cannot help.
Jan 11, 2015 | Coleman Heating & Cooling
Won't egnite, light is flashing 3 times.
On a call for heat, the 24 volt thermostat2.gif sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light). 3 blinks may be a restriction in either the air intake, exhaust pipe, condensate hoses air filter or a bad pressure switch or connection.
Oct 18, 2009 | Coleman Heating & Cooling
Hello I have a goodman gas furnace
Oct 18, 2009 | Goodman Heating & Cooling
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Running out of LP??
Yes. The ignitor is trying to find fire and it can't. That's an ignition error. It should go away once you get fire to the sensors. You might have to hit a reset button, it all depends on the heater.
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace ignition failure
the only thing you can do is turn it off for a couple minutes and try again sometimes you get it to lite off on retry otherwise call tech
Feb 04, 2009 | Coleman Propane Forced Air Heater...
I have a Goodman air heat unit that will not come on.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
Jan 27, 2009 | Goodman GMS90703BXA Heater
Ignition failure. Relatively new furnace - under 5 years old.
You can replace a hot surface ignitor if you are careful not to touch the silicon surface. The oil from your hand may cause the ignitor to fail. make sure to turn off electric supply before attempting. You will probably need an OEM (from a coleman dealer) ignitor.
Usually best to bring the old one with you to make sure you get the right one with the right wire terminals. Or you can wire nut a new one to the old terminals. Could also be a dirty flame sense rod.
Hope this helps.
Matt
Dec 28, 2008 | Coleman Propane Forced Air Heater...
Goodman furnace blinked 1 time
Furnace attempted to start but failed after so manay tries. This may help you.
Sequence of operation, Gas Furnace.
This is why we technicians earn the big bucks!
Dec 05, 2008 | Goodman GMS90703BXA Heater
Ignition failure code on
Sounding like a flame proving device is failing to sense flame. Try to clean the device with some steel wool. It is located right next to the last burner looks like a thick wire. Take the steel wool and gently rub the carbon that has built up off. Should only take 4 or 5 strokes. Let me know it that did it. Ken
Nov 30, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
769 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
