Question about Panasonic Home Theater System System
Can't get tv sound from home cinema system speakers
Hi, I have a Sony Bravia TV (KDL 20S2030) and a Sony Home Cinema System (DAV IS50) connected to each other through a HDMI cable and also an audio cord (a red plug and white plug at each end of the cord), but I can't get any sound to come through the cinema system speakers when watching a tv programme. I have set the function on the home cinema system to "TV" as per the Sony instruction manual, but nothing. The manual says the "System Audio Control" function will activate automatically so that the tv programme sound is played through the cinema speakers, but this doesn't happen. Hope someone can help! Thanks.
  • Jason Edinger May 11, 2010
    Start fresh with me.  Give me a brief description here. Tv is a Bravia kdl 20s2030, home cinema system dav is50 (will l look that up later). What does the cinema system do? Is it a dvd player, etc? How many sets of hook ups does it have? (By set, i mean audio and video, so if it's got a component set, that's 5 plugs.)
You need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Posted on Dec 26, 2008
Cant hear my digital tv through my home cinema speakers
http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Dec 07, 2013 | Samsung HT-X200 Theater System
Sony BDV 370 home cinema system and Sony 40hx703 television. The home cinema plays disks etc. through the cinema speakers. But will not play television sound through the cinema speakers it is connected...
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
Aug 29, 2010 | Sony BDVE300 Theater System
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
HDMI Communications Failure?
Hi
Did you ever get this resolved as I have the same problem
Jan 09, 2009 | Audio Players & Recorders
No sound when viewing normal TV broadcasts
You need to have either the red/white audio cable connected from TV out to cinema system in or a optical or coaxial cable tv out to cinema in.
Nov 30, 2008 | Sony DAV-IS10 System
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
Panasonic Home Theater System System Logo
460 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
