Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but believe previously loaded with Windows XP - do not know which edition. Have tried everything without success. Thanks Chris
    Scholar:
  • 52 Answers
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Posted on Dec 05, 2008
Advent 4213 Netbook 0xc000000f
The first thing I would try is to try to start the computer is Safemode. Safemode is a way of loading Windows without loading all of it. It only starts up with the most basic stuff that you need to help you diagnose other problems.
To start in Safemode, turn off the computer. Turn on the computer, and immediately begin pressing the F8 key. Press it once every half of a second, and keep doing this over and over and over. If the computer allows you to get into Safemode, then you have a chance to try to Restore the computer to an earlier point.
If you cannot accomplish anything using this method, then you may need to find someone who has an "external cd drive." This will make it possible for you to put the original Windows discs in and do a repair that way. This assumes you have those discs! If you don't have the discs, you may be able to buy them from Advent. I would suggest going to their web site to see if they offer any other solutions!
I just looked at the Advent site located here: Advent. It appears that your recovery discs are actually not burned onto discs when you first get the machine. You are supposed to put one of those USB drives (thumb drive) into the machine when it is still working right and copy the recovery program onto the USB drive. Maybe if you can get the computer to start in Safemode, then you might be able to copy the recovery program as instructed on the Advent website above. Just click that link and read about it.
Oct 21, 2012 | Advent Netbook
Advent 7113 laptop very slow would like to return it to factory settings but dont know how help
After researching all the information online, I have put up the maximum possible detailed steps to help you out:
Your Advent computer uses the latest recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
1) Restart your Computer.
2) Press F10 repeatedly until the message "Starting System Recovery" is displayed.
3)
The recovery will load and display a menu of options:
(a)
Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
(b)
System Recovery - No format: this will reinstall Windows®, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
(c)
System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
4)
Select the Non-destructive recovery option and press Next.
5)
You will be informed about System Restore in Windows, click Yes.
6)
The recovery will begin. Once this is complete click Restart.
Here are some additional information:
a) Press the ALT and D keys at the Windows style recovery menu options to access a command prompt. This will allow access to C: drive.
b) The command prompt will default to c:\minint\system32 where you can run a variety of tools including CHKDSK.EXE.
c)
For more information on these options, please read the Advent recovery trouble-shooter.
Advent recovery trouble-shooter:
If a user is experiencing recovery problems on an Advent PC, then try to follow these steps.
Note: These steps will remove all personal data and all applications installed after the PC was purchased. Where possible ensure that all data and personal files are backed up BEFORE trying these destructive diagnostic steps.
1)
Check the integrity of the recovery CD, or the update CD.
2)
It is possible to verify the integrity of the recovery CD, or the update CD from within the Recovery programme.
a)
Boot from the recovery C.
b)
At the ‘Press R to display system recovery options’, press ‘R’.
c)
Once in the System Recovery screen, press ALT + D to access the WinPE command prompt.
d)
Type in Xcopy D:\*.* /E /V C:\ and press Enter.
e)
D:\ is the CD ROM drive letter
C:\ is the HDD
/E copies everything
/V verifies the data with a CRC check
f) If there is an error with the CD, then you will get the message:
File creation error – Data error (cyclic redundancy check).
g) If there are no errors, then you will be left at a prompt again.
3)
If Windows® is accessible, then boot from the recovery CD.
4)
5)
Once in the System Recovery screen, press ALT + D to access the WinPE command prompt as below:
6)
Type COPYSI and hit Enter. This will unhide the user's smartimage (this may take a few minutes to complete).
7)
Return to Windows® & copy the contents of the C:\Update CD\ folder to CD (N.B. Do not copy the ‘Update CD’ folder itself). Ask the user to label this ‘UPDATE CD’.
8)
Start with the recovery CD ROM in the CD drive.
9)
At the ‘Press R to display system recovery options’, press CTRL + BACKSPACE to get the hidden menu as below:
10)
Choose option:4 (Clear the partition table of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
11)
Choose option:5 (Erase the Master Boot Record of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
12)
Choose option:7 (Create a primary partition on drive 0x80). Do not restart the machine during this process. Option 7 may sit for up to 10 minutes with a flashing cursor as it creates the partition. If the HDD LED is flashing, then you know that the process is proceeding.
13)
Once the HDD partition has been created you will be returned to the ‘Press R to display system recovery options’ screen. Press ‘R’.
14)
The recovery should go straight into a full destructive recovery, and will ask for the update CD which we have created.
Hope this Helps.
Please feel free to ask further questions.
Aug 15, 2010 | Advent Netbook
How do you restore a Advent 7081 laptop to factory settings
to fully restore it to as you brouth it you will have to install windows againe with a oem disc
Jun 03, 2010 | Computers & Internet
I was to reboot/get into recovery on my advent 7087 f10 doesnt work!
There are two ways to start the recovery -Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
second one is
In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
with regards
balisonu79
Jan 04, 2010 | Advent Netbook
Need recovery discs for advent 7096 laptop
Visit the following site:
http://www.uktsupport.co.uk/advent/laptop/7096.htm
You will find the information under "Recovery Disk" section.
Nov 02, 2009 | Computers & Internet
Remove the emachine/PC ANGEL RECOVERY SOFTWARE
PC angel isn't installed as such it uses the desktop.ini to load its software.
desktop.ini is used to by windows to customise the view of individal folders in windows.
if you know how go to command prompt
type in;
attrib -h -r -s -a c:\folder\*.* /d /s
( replace c:\folder with the drive/folder of the protected folder )
next type in
del c:\folder\desktop.ini
( Again replace c:\folder with the drive/folder of the protected folder)
Bye bye protection for that folder
Apr 14, 2009 | E-Machines (T2824) PC Desktop
Hard drive compressed/bootmgr compressed
U DONT NEED A RECOVERY DISC TO FORMAT YOUR HDD ALL U NEED IS THE WINDOWS DISC U WILL USE TO LOAD WINDOWS THAN START YOUR COMPUTER UP BUT WITH YOUR CD ROM TO BOOT UP FIRST U WILL THAN HAVE TO VERIFY IF U WANT TO UPGRADE YOUR SYSTEM WILL CHECK IF WINDOWS WAS INSTALLED BEFORE AND ASK U DO U WANT TO FORMAT AND YOU WILL SPECIFY YES DELETING ANY OTHER PATITIONS
Feb 06, 2009 | Advent 4211c Notebook
I have lost my recovery disc supplied with my advent 7000 laptop can you help please
advent 7000 recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
  • There are two ways to start the recovery -
    • Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
    • In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
  • The recovery will load and display a box with one option:
    • Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
    • System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
    • System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Nov 05, 2008 | Computers & Internet
I have a laptop that i have only used a few times, and when it boots up it gives you the vista set up screen, with is very simple to complete. When i go to reboot the laptop always after i have completed...
PC Angel will keep coming up when you try and restore the system with the discs you have. Its an integrated solution for PC manufacturers to deploy there systems. The issues you are having usually only come about when you are either trying to install the software on a system it wasnt intended for it does read the hardware and check it the correct computer. or if you have a corrupt disc. Couple of things you can do, firstly you can contact the computer manufacturer support and tell them you are having the issue, or you can delete the disc partition and re-install vista from a different disc. Deleting the partition is easy and just requires software, do a google for free partitioning software and you wil find it. As for getting an IDE converotr, you might find that the laptop if its a new one, has an ATA drive and not an IDE, most of the new laptop have ATA drives installed.
Aug 26, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
