Question about RCA CC4252 Camcorder
RCA Camcorder I installed new belts, and lubricated all moving parts. But, apparently, while doing the oiling of gear spindles and greasing slides, i inadvertantly moved something out of sync. The unit now will only go into play mode and cycle back and forth as if it doesn't know what to do. Also, it won't eject tape. How do I realign the gears to get everything working again ? I seldom do repairs, but I have had success with the vcr's that I have worked on. I am constantly using three vcr's on a nightly basis to record programs to watch later. But, I don't use the camcorder often.
    Sniper:
  • 80 Answers
It's been a while since I worked on the RCA full size camcorders as well. It sounds as though the load motor is "jogging" because the mode switch is not in time with the mechanism. I think there are timing marks on all the cams and gears in the unit and an indicator arrow on the mode switch. Set the mechanism to the "stop" mode and align the main cam index mark to the load motor drive cam, be sure the mode switch arrow points to the load motor drive gear "hole", this tells the micro the unit is in "stop" mode. Good Luck Joe Weibel customelectronics.org
Posted on Feb 16, 2007
How to fit the mower deck belt on a ***** LT130?
The best way is to remove the deck from the mower. At this time you should grease the pulleys and spindles. there are four post that hold it. two on either side and one in the front. they are held by cotter pins. lower your deck level down makes it easier. you will have one engagement cable that just pops out it has a spring on it. then slide it out from the easiest side or pick the mower up and pull deck out . at this point it will be apparent where the belt goes and do your your other maintenance of cleaning and lube. factory says lube spindles every 8 hours of use.Then put it back under and re attach.
Sep 15, 2014 | Husqvarna Lth 130 Riding Mower Illustrated...
Replace grease bosch rotary hammer
There is no grease but oil used in this tool There is a special consumables kit for to order But BEFORE you made a self service for this machine there could be a rip somewhere in the spindle control first by ringing listen to the sound tap on it it with a piece of metal that the spindle sounds well without also all in and outside parts naturally and off if it does is the sds chisel drill conduction inside the spindle is not round toppen instead of square topped because of faultering on the chisel or drill in short time to expect. in that case if the spindle is bad its better to remplacement the whole tool by Bosch for the working hours on all parts are reached, but if the spindle is smooth order 1 615 437 511 oil reservoir and 1 617 000 A16 thats the right maintenance partsset for this machine and its is easy to service by yourself a little 2 or 3 hours without special tools for special kevlar rings like some other brands often have. but a bank vice and some little screwdrivers noseplier, shaft retaining ring pliers a solvent cleaner for the old lubrication to remove.
AND IMPORTANT dont forget part 104 best to give that o-ring some grease that it will not move out by insert the spindle (sometimes)
one thing is very important there must inside be 2 adjust rings between the gears 47 and 51 if there is only one shimring = used then order some shim rings ( there must be made an adjust between 0,08 and 0,22 mm between the gears tooth but only when there is only 1 ring was used that can be happen in a rare case. the drawing is to find also by bosch in america the partnumbers are the same.
http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=ZdEJ7pFj&p_p_auth=R78yYhDo&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMDdhNWQ4RkJCO3NpZD1Zdks0RVZOU3dzVm1OZ3M3YnNlazZselpkRGtMODVwSi1QTTd1dEh5ZERrTDg1cEotUE09
Oct 16, 2013 | Bosch 1 916 SDS Max Rotary Hammer Drill...
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
My recors player plays slow when i put it on 33 1/3 rpm and 45 and i dont know why. it also sat out at my dads house in the cold for 2 years. its a mid 80's player with the 8-track and tape deck and idk...
The turntable or motor bearing may be gummed up, or the belt or drive tire may be slipping.
The turntable is usually held in place by an E-shaped spring clip right at the base of the spindle. Carefully spread it with a flat-blade screwdriver just enough to slide it out, but keep a hold on it with a finger because sometimes they will try to fly across the room. Once you have the clip off, you can lift the platter off to service the bearing. Wipe it clean with a soft rag and lubricate with a very light oil (sewing machine or clock oil will work).
Often the automatic drop mechanism will work poorly if the turntable has been sitting a long time. Sometimes the problem is the aforementioned sticky bearings, but occasionally it is necessary to clean and grease the sliding parts.
If the rubber drive component is slipping, you may be able to use rubber conditioner to restore it (supplied by MCM Electronics), otherwise you can get replacement belts from the same company.
Jan 06, 2011 | Audio Players & Recorders
Do i need any special tools to change hub bearing on a 95 honda passport
No special tools needed, this Honda has the old type inner and outer wheel bearing's, remove cotter pin, spindle nut slide rotor out, remove wheel bearing, repack new bearing with grease and don't forget to replace grease seal's, install new part's adjust spindle nut and install cotter pin.Good luck,hope this was very helpful.
May 13, 2010 | 1995 Honda Passport
How to replace rear wheel hub
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
  1. Raise and support the vehicle safely.
  2. Remove the wheels.
  3. Remove the brake drum or brake disc.
  4. Remove the hub grease cap.
  5. Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
  6. Remove the outer bearing and cone assembly.
  7. Remove the rear hub from rear wheel spindle.
  8. Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
  9. Remove the inner bearing cone and roller assembly.
  10. Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
  1. Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
  2. If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
  1. Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
  2. Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
  3. Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
  1. Install the hub assembly on the spindle.
  2. Install the outer bearing cone and roller assembly on the spindle.
  3. Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
  4. Install the new cotter pin.
  5. Install hub grease cap.
  6. Install brake drum or disc.
  7. Install the wheels.
  8. Lower the vehicle.
May 04, 2010 | 1998 Ford Windstar
Oil leaking from gear box on hammer drill
Where is the oil leaking from. By the chuck, or the selector knob, or is it leaking from where the gear housing meets the motor housing. I could be one of 3 things. There is a seal between the two housings that could be damaged, not likely though. There is an oring on the selector knob that can get worn, and there is a sealed bearing on the spindle that should not let any oil through. There should not be any oil in this tool for lubrication. Grease is used in this tool for lubrication. If you are getting oil or a liquidy type substance coming out it is more than likely the grease has broken down and needs to be replaced.
Oct 14, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Where to I oil this machine
Get a good quality sewing machine oil, not general purpose oil as that will gum up over time.
If you don't have a manual, a good rule of thumb is to oil everything that moves, but lightly. Don't oil the motor or belts and use lubricant (usually sold in a tube), just a little dab, for the gears. The same with oil, just use a little bit and then move the machine by hand and you will see where the parts move.
Take off the top to see all the moving part and don't forget to oil underneath the machine as well.
You can find manuals for sale on a number of online sights and manybe even Sears.
Patience
May 22, 2009 | Kenmore 16622 Mechanical Sewing Machine
I have a JVC JL A20 turntable. I installed the black rubber band (belt)around the ring on the bottom of the subplatter and the pin. The pin turns when I move the arm over the platter. But the pin does not...
Your center pin is seized. You need to remove the three screws holding the center pin. Then remove the screw holding the shaft in place. Lubricate it with a light grease/oil and reassemble. I used spray lithium grease, but don't know if its correct.
Apr 26, 2009 | JVC Audio Players & Recorders
Model KSM90 10 speed ultra power stand mixer leaking oil at the shaft where mixer tools attach. Is there a repair kit which includes a oil seal or something like that at a reasonable price?
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
RCA CC4252 Camcorder Logo
87 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
