SOURCE: Pioneer GM-5100T Car Audio Amplifier IS THE SYSTEM CONTROL WIRE THE SAME AS REMOTE WIRE
System control is the same as the remote turn-on from the head unit.
SOURCE: Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
SOURCE: I have a Pioneer GM H22 amp. Powers up nice, fan
On Pioneer, Green wires are left spkrs, Grey is right spkrs solid is positive black stripe is neg.
SOURCE: A wiring/pin identification for old Pioneer GM-4
Can most probably,can't remember so clearly.Tell me how many wires ther are and what's all the colours.If you could send a pic as well.
