Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelight chainsaw pulls hard. can't get started
Pulls hard, pull the plug pulls easy.
  • Anonymous Apr 16, 2009
    i cant pull the string to start it but i can trun the wheel that the string hooks to to start it so what schould i do
  • Allen Neal
    Allen Neal May 11, 2010
    does it have a compreeion relase button on it if push
  • 211 Answers
Hi Remove the fan housing with the starter mecanism.Pull the starter and check if it works properly.Try to turn by hand the flyweel.It is normaly to feel dificulty only when the piston comes up in the cilinder.If you feel difficulty all the time there is too much preasure on the cilinder walls(piston rings friction.Easy kick the end of the crankshaft with a hammer until the piston moves easier in the cilinder
please leave a rating.Thanks
cheers savumihai71.
Posted on Dec 07, 2008
When pulling cord to start it pulls hard take plug off its easy can't get it to start
REED VALVE STUCK. DOSEN'T OPEN TO RELEASE COMPRESSION. TAKE OUT PLUG - SPRAY A LOT OF CARB CLEANER IN PLUG HOLE, LET SIT FOR 5 MINUTES. PULL TO CLEAN OUT CYLINDER A FEW TIMES. THEN TAKE A LITTLE OF GAS MIXTURE USED IN SAW AND DO THE SAME THING. REPLACE PLUG AND TRY IT. IF THE SAME THING IT WILL HAVE TO BE TAKEN APART TO FIX.
Aug 10, 2014 | Garden
Sounds like it seized or is starting to. I would put a little two stroke oil in the cylinder about 20cc maybe a little bite more 50cc if it is really hard to pull.... Leave The plug out and pull on it about 30 seconds hopefully when the plug is back in it will run... goodluck. If its really tight needs to be rebuilt....
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Poulan 38cc wont start
quick check would be to pull muffler from engine check the screen if the screen is ok start engine if it starts without the muffler the muffler needs to be replaced.if it still dont start do pressure and vaccum checks on carb.
Jan 28, 2013 | Poulan Garden
My stihl chainsaw pulls hard even with plug removed
It might be just the sprockey bearing dry or seized, if the bearing does not turn freely on the crank it will try to turn the chain as well when you try to crank it, pull the side cover off, turn the sprocket by hand if there is a lot of resistence, grease uup the bearing or replace if damaged.
Jun 30, 2012 | Garden
Echo CS346 Very hard to pull starting rope, feels like it has 3 detents. However, with spark plug removed, it pulls smooth and easy. Could I have a stuck exhaust valve.
Most chain saws don't use "valves" but just have an exhaust port from the side when the piston is down. You MAY be just carboned up in the cylinder head so compression is too high causing extra hard force to go over the center. Maybe you are running with too much oil mix or there could be a failure of the con rod bearing.
Nov 22, 2011 | Echo Garden
Poulan 2150 very hard to pull start..first time this season trying to start...seems like too much compression...pulls nice and easy with spark plug removed..with the spk plug in...very hard to pull..still...
If fuel leaked into the engine over the winter, it could cause very hard-to-pull problems. Remove the plug, ignition off, with the cylinder/head down, pull it through vigorously to see if expels any fuel. Replace last year's fuel with fresh fuel mix. It's a good idea to allow the engine to run out of fuel before storage. Does this engine have a compression release? If so, it may need cleaning to work properly. Hope this helps!
Apr 20, 2010 | Garden
HARD TO PULL CORD WITH SPARKPLUG IN CHAINSAW. IF
sound like hydraulic lock,try leaving the spark plug out and pull it quite a few times with the spark plug hole facing the ground, this should shoot the offending fluid out.
might work ?
May 01, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
494 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
